Which Cams?
Old Nov 10, 2007 | 08:05 PM
JF7044's Avatar
JF7044
Default Which Cams?
Im riding a 2007 RKC with Rinehart truel duals, K&N Filter & PCIII. Can anyone tell me which cam setup I should be using? Im looking for added tourqe in the mid range 2000-5500 rpm.
Old Nov 10, 2007 | 08:11 PM
DonnyI's Avatar
DonnyI
Default RE: Which Cams?
Head-Quarters TC-500-HC uses stock hydraulic chain tensioner system. Asymmetrical double patterned cam is an absolute winner as a bolt-in cam. It will increase power across the whole range and is compression friendly too. Designed as a bolt in replacement, it broadly enhances the power curve.
Old Nov 10, 2007 | 08:26 PM
JF7044's Avatar
JF7044
how do the HQ tc-500s compare to the SE 255 or andrews tw-26
Old Nov 10, 2007 | 08:30 PM
Harleypingman's Avatar
Harleypingman
Rockdude: In your 96, the HQ 500 will give you ~90 hp and 90+ torque with the PCIII dialed in. I have the 88" version, HQ-0034, and it works great with my Rinehart TD's and SE a/c.
Old Nov 16, 2007 | 12:28 PM
BAGTHIS's Avatar
BAGTHIS
Anybody have a set of the TC-500's in a 96" yet? If so, what do you think?
Old Nov 16, 2007 | 12:52 PM
IceHeritage's Avatar
IceHeritage
I have a SE211 and it's real Sweet
Old Nov 16, 2007 | 01:14 PM
PhilM's Avatar
PhilM
I have not used them in a 96 yet, but I have installed the 0034's (same gring, only for older style motor) in several 88's with great success.
Where's Boargard? He just installed some 500's in his 07 96"er... I have not ridden it, but he said it's better then the 26's were, even with almost no time for his TMax to retune. I'd like to hear how it's doing now that he has some miles on it..... Jason, you out there reading this?
Old Nov 16, 2007 | 02:02 PM
TX_RG's Avatar
TX_RG
I just got Woods TW7H in mine
Old Nov 16, 2007 | 02:45 PM
jferna's Avatar
jferna
I'll be looking to do the same thing next spring and have done a search and read all the threads on this site about cams. Here is an interesting site that has cleared up a lot of my questions on cam selection.
http://www.nightrider.com/biketech/h...e_upgrades.htm
Old Nov 16, 2007 | 04:53 PM
Donnylee's Avatar
Donnylee
I am loving the 211s in the 96! Power right where you indicated you wanted it.
