true duals or not ?
Old Nov 19, 2007 | 01:43 PM
Chicago Spike's Avatar
Chicago Spike
Default RE: true duals or not ?
True Duals = True Sound
Old Nov 19, 2007 | 01:44 PM
Chicago Spike
Plus less heatwith the crossover being removed
Old Nov 29, 2007 | 04:31 PM
mr bigjim's Avatar
mr bigjim
I HAVE VANCE AND HINES BIG SHOT DUALS ON MY ROAD KING,,,,SOUND GREAT, HAD TO MODIFY THEM SO I COULD GET THE BAFFLES OUT EASIER WHEN I WANTED THEM OUT, WHICH IS MOST OF THE TIME,I CAN TAKE THEM OUT IN 3 MINUTES NOW,WHEN THEY ARE OUT AND YOU LET OFF TO SHIFTER, WHEW,,,,YOULL GET WOOD MY MAN, LOSE A LITTLE LOW END POWER, BUT HELL I DONT CARE , I ANINT RACING ANYWAY, AND PUTTING A DFO ON IT,,JUST NOT SURE WHAT THE SETTINGS WILL BE WHEN THEY ARE OUT
Old Nov 29, 2007 | 05:25 PM
TruBluUltra's Avatar
TruBluUltra
ORIGINAL: ironhead3fan
How much difference does the PCIII and true dual headers make? I already have the Stage I download, VH slash cuts, and SE air cleaner.
When you do things in the correct order (IMO), it makes all the difference..this is how my mods went:
1) Trashed (literally) stock mufflers, replaced with used (cause I'm a cheapa$$) Supertrapps with internal discs (19/18).....at appr. 200 miles
Results: Much better sound than stock....didn't sound like a sewing machine
2) Trashed stock head pipes, replaced with V&H duals....at appr. 500 miles
Results: Improved sound (stereo instead of mono)...increased sound level a little, didn't notice losing anything down low (loss of torque)
3) Trashed stock airfilter and replaced with SE air filter, installed PCIII USB....at appr. 1000 miles
Results: Greatly (subjective, yes I know) improved sound, throttle response, and overall "yee-haw" appeal lol
4) Gutted Supertrapps, removed all discs, stripped out what little packing was left (edit...at appr. 7000 miles)
Results: Now THIS is what a Harley should sound like (again, IMO)....and yes, I have no problem listening to the stereo at most anytime (specifically, cruising 70-80 on the freeway)
Old Nov 29, 2007 | 07:25 PM
Jeepin_Lawyer's Avatar
Jeepin_Lawyer
I am suprised more people have not brought up the huge loss in low in tq. On my bike I went from true duals to a 2-1 system and my tq numbers went up by about 10 starting at a little over 2K rpms and continued steadily higher through a little under 4K rpms where the pipes became similar in performance. So the true duals cause a large loss right in the place most people do the most riding. I have a dyno sheet to back this up that I need to post up.
Bottom Line: The true duals sound and look AMAZING!! The stock headpipe and 2-1 system PERFORMS!!
Old Nov 29, 2007 | 07:52 PM
Chicago Spike
ORIGINAL: Jeepin_Lawyer
Get the duals installed before you ever ride your bike and you never notice the loss
Old Nov 29, 2007 | 08:04 PM
vettedog72's Avatar
vettedog72
I have enough torque to spare a little for the sound effects. TD's and Rineharts, not too loud at idle and very loud at WOT. I would guess a good fuel pack gadget with a good dyno tune would give a rule of thumb of 10% moe.
Old Nov 29, 2007 | 08:15 PM
BillyG0856's Avatar
BillyG0856
I had the SE air filter installed, SE slip-ons, and the remap done @ about 150 miles...bike runs ok. Still hot though. I like the sound I have now with the SE Slip-ons...nice rumble when Im cruising. I dont really want alot of noise....a little more is tolerable. (sorry...just my taste)
My questions are...
[ul][*]Is it worth the cost of true duals for the heat issue? My main concern is getting rid of the heat.[*]Can I still use the SE slip-ons? ( I like the sound) Dont really want to buy new mufflers yet.[*]SERT or PC III? (considering warranty issues) I have no idea which way to go. Seems it's a "6 one way...half-dozen the other"[/ul]
The bike moves plenty fast for me. IM not sure I even know what Im asking here...so I'd appreciate any and all comments.
Thanks in advance....
Billy G
Old Nov 29, 2007 | 08:35 PM
Jim Dawson's Avatar
Jim Dawson
I bought a set of Torres duals but haven't installed them yet. I got a good deal at 20%, before Torres raised the price. I can't decide if I want to install them, buit V&H Dresser Duals, or stick with the stock headers. I have Rush 1.75 slip-ons and I don't want the bike much, if any, louder. I just like the looks of the duals and want to lose the heat of the crossover.
Old Nov 29, 2007 | 09:37 PM
greg09997's Avatar
greg09997
Do this and keep all your low end torque.
ORIGINAL: xxxflhrci
Using the same mufflers it will be just a bit louder.
I think you are spending too much at $650.00. You can get the pipes shipped from various vendors for right at $300.00. Bolting them on is an easy job. Do it yourself. Then, retune if necessary.
