Stainless Steel Vs. Diamond Back Control Cables
Old Nov 12, 2007 | 07:51 PM
billybobsrk's Avatar
billybobsrk
Default Stainless Steel Vs. Diamond Back Control Cables
Going to install new handlebars on my 97 Road King and was planning on going with stainless steel control cables until I saw the diamond back cables. I knowthe vinyl sleeves on the stainless cables will yellow in time, but read that the diamnod back have non yellowing vinyl sleeves; would appreciate hearing pros & cons on both types or anycomments from those of you that have installed them.
Old Nov 13, 2007 | 05:48 AM
Pastor John's Avatar
Pastor John
Default RE: Stainless Steel Vs. Diamond Back Control Cables
I had the Diamondbacks on my '07 Road King for about a year and they stayed bright and clear (probably not a sufficient long-term test, though!). My only complaint would be that the plastic coating is somewhat fragile and stiff. If I routed the cables with a little too much curve, the coating wanted to bunch up; not a real big deal in my case, but it makes me think you would want to be careful during installation. I like the bright silver finish of the Diamondbacks.
Old Nov 13, 2007 | 06:00 AM
OneBlackFly's Avatar
OneBlackFly
I agree on the fragility of the DB outer material. My cables, clutch one in particular, are in poor condition after about one year. From what I've read and seen, consider Barnett cables in place of H-D ones. From riders with whom I've discussed cables, Barnett cables are the most durable. The outer material on the D-B cables cracks and that crack then lets dirty and oil in, leaving a black area on the cable.
Old Nov 13, 2007 | 08:03 AM
Manish_Hawg's Avatar
Manish_Hawg
Go with the Magnum Sterling Chromite II cables. Contact Shooter64 and he will get you the best price. You won't be disappointed.
Old Nov 14, 2007 | 01:47 PM
oneshotdog's Avatar
oneshotdog
So from what I hear, Magnum Sterling Chromite II cables are the way to go
Old Nov 14, 2007 | 01:48 PM
rome304's Avatar
rome304
Magnum Sterling Chromite II cables .
Scooby1426
Audio Systems
Mar 11, 2018 06:29 PM
JunglaMan
Mar 4, 2017 03:15 PM
HarkinsBG
Apr 9, 2013 12:21 PM
Skip
Exhaust System Topics
Feb 10, 2009 04:48 PM
Manish_Hawg
Aug 23, 2006 05:34 PM
