Bike Jack
Old Jan 4, 2009 | 11:04 AM
  #41
FYRDOC's Avatar
FYRDOC
The J&S jack is definately sturdy.....I'd seen the videos and what not.....the other day, with the whole front end off(wheel,tire,fender,forks,etc.) I climbed up on my RKC with it all the way up to try out my bar positioning......my neighbor(a Sears jack owner) was freaking out and looked like the old school fireman with the big catch tarps.....he was waiting to try and catch me and the bike......but alas, no worries!!
Old Jan 4, 2009 | 11:23 AM
  #42
hogdevil's Avatar
hogdevil
I've seen the videos on the J&S jack on their web site. Sturdy it is and I completely agree about risking a $20k+ bike with a $130 jack.
The J&S jack has a clearance of 4 inches. If the frame on the bike is lower than 4 inches from the ground then the awesome J&S jack can't get under the bike to lift it.
If you feel the need to build ramps, use planks of wood under the tires, etc. to get the bike high enough because your are using a more expensive and higher quality jack to get under the bike then go with the jack from Harley-Davidson. The crank handle will allow you to safely bring the bike down at a controlled speed of your choosing. The videos on the J&S web site show that the jack has an abrupt drop the last few inches.
If I'm running the bike up on boards to get the frame higher off the ground then spending the cash for J&S then I'll spend a few extra dollars and go with the Harley crank to get the additional safety. After all, we're talking big bucks for a better jack to protect an expensive bike. Might as well get the full safety benefit of the crank and controlled lowering speed.
Harley jack requires straps and the J&S doesn't? I would still use the straps because when you spend this much money on a bike and a jack it's not about saving a few dollars it's about not trashing your bike. I would probably use straps on the J&S anyway just to make sure.
Old Jan 4, 2009 | 11:47 AM
  #43
Clint55's Avatar
Clint55
Originally Posted by captjon37
I was a cultured pearl diver for 35 years and i can tell you that no one here knows better than me that the sears red works just fine.
I knew it!! Everything makes total sense now. A combination of pressure induced psychosis and nitrogen narcosis has resulted in total and clear motorcycle jack awareness. Seen it hundreds of times.
BTW, ever run across any muffs on those dives? I’ve heard they like to hang out around the pearls.
Old Jan 4, 2009 | 12:48 PM
  #44
gregsworld's Avatar
gregsworld
bump bump
Last edited by gregsworld; Jan 4, 2009 at 12:53 PM. Reason: didn't finish the message
Old Jan 4, 2009 | 12:50 PM
  #45
gregsworld's Avatar
gregsworld
HAHAHA !!! Here we go again. I know everyone's been waiting on me. I LOVE THE YELLOW JACK !!! Really. It is a quality built jack that does a great job with both my Road Glide and Warrior. And no, I do not think it tops a full length jack costing $600. But for less than 2 bills, I have never seen a better quality jack. My favorite thing is how low it can go. My older jacks couldn't get under both of my lowered bikes. This one creeps to the floor.
Old Nov 21, 2009 | 06:49 AM
  #46
Iceman24's Avatar
Iceman24
Originally Posted by TexasRanger
Do yourself a favor and check out the Kobalt ATV jack at Lowes. It fits under the Ultra on the sidestand, bike comes down as fast as you want it to, and it's got a lifetime warranty. Only drawback is they sponser Jimmy Johnson.....
Good one...I'm not a JJ fan either. Thanks for the tip w/the Kobalt b/c I'm searching for a m/c jack & haven't fount one I like a/o yet. Will take a trip to Lowe's today.
Old Nov 21, 2009 | 07:03 AM
  #47
Iceman24's Avatar
Iceman24
Originally Posted by reeac
Check this video of the yellow jack http://www.youtube.com/watch?v=8eJk57F2XLs
Notice how hard it is for this "big dude" to push the bike around & this jack works like a "floor jack" w/the screw handle (fast drop w/weight) There's no way to swap the hydraulic jack if it fails (like the cheaper sears, HF, etc.). Don't really care for these alum models.
Old Nov 21, 2009 | 07:10 AM
  #48
RBowers's Avatar
RBowers
I have the Craftsman yellow jack and I only use it for cleaning. For me it works just fine for what I use it for.
I do know someone with the same jack and he seems to leave his bagged Fatboy on it 24/7 because he's afraid to flat spot his tires.
Old Nov 21, 2009 | 07:11 AM
  #49
clutchglass's Avatar
clutchglass
Default Actualy That's a GREAT Jack
That looks to be the exact jack I have. It's also a Sears craftsman jack. It comes with lift extensions for ATVs. It also is not a fast drop if you are gentle with the handle, and it has a built in mechanical safety (In case of hydraulic failure). I've had mine for about 4 years and it's the best jack I have ever owned.
-clutch-
Old Nov 21, 2009 | 07:22 AM
  #50
dawg's Avatar
dawg
