Need Part #
Old Nov 17, 2007 | 09:54 PM
mopar7's Avatar
mopar7
Default Need Part #
I need the part number for 2006 Street Glide lower fender support. This is the V shaped bracket that bolts to the center welded stud at the bottom of the rear fender and attaches to the saddlebag support rail on each side. The bumper support rail on my Ultra will not fit.
Old Nov 17, 2007 | 10:59 PM
Harleypingman's Avatar
Harleypingman
Default RE: Need Part #
It's 91140-04.
If you need any other part numbers you will probably find it here from a previous post from 11/30/06:
"Ground Effects, price $63.64 part no. 59739-06(followed by a color code: BXT (cobalt blue), BPY (black pearl), BPS (black cherry) and DH (vivid black);
Rear Fender Light Assembly, 69375-06, price $49.34;
[EDIT: Instead of this light assembly that is a running light only, you can use a newer version introduced in '07 that is a running light and brake light, HD part no. 68358-07, list price $89.95.]
Conduit, wire harness, price $6.47
Pin Housing, 3-way, price $.82, part no. 73103-96BK;
Pin Terminal, part no. 73190-96, price $.31;
Stud Plate, part no. 59818-06, price each $5.95 (requires 2);
Ground Effects Support, part no. 59790-06, price $5.40;
Bumper, part no. 59581-05, price $2.73;
Screw, part 3596, price $.72 (2)
Flange nut, part 7499, price $1.16 (6);
Grommet, part no. 59778-06, price $1.25 ea.(2) Use these if you aregoing to install the HD two-up detachable tour pack rack mounting hardware;
Plug, part no. 59746-06 price $1.25 ea. (2) Use these if you are not mounting the two-up detachable rack mounting hardware. The stockSG uses one of these in the right filler strip, and one grommet in the left for the antenna.
If your Touring bike has a rubber bumper, you will need to order "Bracket," part no. 91140-04, as this part is what connects the saddlebag support brackets to the fender. If you look at a Road Glide, RK Custom or FLHX you will see this bracket and how it takes the place of the bumper bracket on the other EGs and RKs.
If you want to lose the pancake turn signals or, if you already have the bullet turn signals and want to duplicate the FLHX's license plate mounted below the brakelight, order Bullet Rear Turn Signal and License Plate Relocation Kit, page 504 of the 06 P&A catalog, part no. 53702-04, price $195 from the same dealer that sold the above parts. If you like your stock turn signals there is not necessary to change them in order to install the Street Glide facia and LED. "
Post pics when you finish.
Old Nov 17, 2007 | 11:00 PM
soos's Avatar
soos
Try 91140-04, Bracket, saddlebag to fender support.
Old Nov 18, 2007 | 06:49 AM
mopar7's Avatar
mopar7
Thanks for the help. I bought a take off 07 front and 08 complete rear fender.
[IMG]local://upfiles/45252/9D47237B27234A62846E59D1B3A32524.jpg[/IMG]
fueler
May 24, 2017 11:19 PM
ksalvojr15
May 11, 2015 05:49 PM
camden
Dyna Parts
14
Feb 10, 2015 11:12 AM
misfitJason
Jan 7, 2012 07:32 AM
Taddeoeg
Jul 10, 2010 09:56 PM
