Fuel Crossover Question?
Old Nov 18, 2007 | 06:51 PM
mtclassic's Avatar
mtclassic
Default RE: Fuel Crossover Question?
this is what I have.http://cgi.ebay.com/ebaymotors/Chrom...spagenameZWD1V A little more money but very nice.
Old Nov 18, 2007 | 06:56 PM
gunnert's Avatar
gunnert
They are fine, but I have 1/8 in NPT fittings on the tank.
Old Nov 18, 2007 | 06:57 PM
mtclassic's Avatar
mtclassic
I bought mine from this guy $39 shipped and was fast shipping. Don't know him from adam but a happy customer.
galvatron10@insightbb.com
Old Nov 18, 2007 | 06:59 PM
mtclassic's Avatar
mtclassic
Can't you make an adaptor or sleeve so you can use the 5/16 or 1/4 inch fuel line? Should not be that difficult to reduce a 1/4fuel line down to 1/8 inch. I would be a little worried with only an 1/8 inch line not much flow rate. Nice tank tho.
Old Nov 18, 2007 | 09:44 PM
Neckball's Avatar
Neckball
1/8" is a lot bigger than the hole in the carb jet, that's the limiting factor.
Old Nov 19, 2007 | 05:26 AM
gunnert's Avatar
gunnert
bump
Old Nov 19, 2007 | 06:38 AM
1flhtk4me's Avatar
1flhtk4me
Is the ID of the fitting actually 1/8"?
Old Nov 19, 2007 | 06:49 AM
miacycles's Avatar
miacycles
1/8" is plenty, the inside of the stock Harley fitting is the same size. If you don't believe it just unhook your crossover and watch the flow. The purpose is just to balance the level in both sides when the level is below the tunnel, not supply fuel to the engine.
Old Nov 19, 2007 | 10:50 AM
gunnert's Avatar
gunnert
No, the inside diameter of a 1/8 in npt fitting is not 1/8 inch. It is VERY small. 1/8" is the outside diameter of a fitting.
Old Nov 19, 2007 | 11:11 AM
Gutman's Avatar
Gutman
sifularson, That crossover disconnect is made by Motion Pro. Only one side has a check valve in it. The other is open.
