BIG SUCKER QUESTION...
Old Nov 18, 2007 | 04:19 PM
profinish's Avatar
profinish
Default BIG SUCKER QUESTION...
When replacing the stock A/C, what do you do with the two breather tubes? I don't see any place they can connect to.
Old Nov 18, 2007 | 04:31 PM
Harley Rulz's Avatar
Harley Rulz
Default RE: BIG SUCKER QUESTION...
Are you putting the stock breather back on or trying to install a Big Sucker?If you're installing the B/S,you do away with the hoses.
Old Nov 18, 2007 | 04:37 PM
ezlife's Avatar
ezlife
Replaced by the banjo bolts (breather holes drilled internally) on the BS
Scootr's Avatar
Scootr
They are in my box of stock hd stuff on my bench with the stock a/c. I suppose you could find something more creative to do with them though.
Old Nov 18, 2007 | 04:39 PM
profinish's Avatar
profinish
Thanks guys... I figured they were useless but wanted to make sure... Thanks!
Old Nov 19, 2007 | 09:08 AM
gman's Avatar
gman
that is why the BS is better than the stock or SE. the breather system doesn't draw oil into the filter, possibly causing misting. it uses the banjo bolts and dumps deep into the throttle body (much like is done on autos). I have both, SE and AN, the have never had a misting issue with the AN.
V-8
Carburetor Related
Sep 5, 2018 02:09 PM
Alias69
Jun 23, 2012 07:18 PM
Salvi
Apr 21, 2011 06:56 PM
ironman_sg
Apr 15, 2011 01:23 PM
wasp
Jan 30, 2007 10:40 PM
