Big Bore Stage II 103
Old Nov 21, 2007 | 11:53 AM
pwrpla's Avatar
pwrpla
Stage II
Default Big Bore Stage II 103
Hello, I am new to the forum and have been following the posts for about two months now. I have an 08 Ultra Classic. I am thinking of adding the SE Big Bore Stage II 103 kit. I know that the after market kits will have more punch, but after researching, the SE kit will fit my needs. My question is, how many hours of labor does it take to install this kit. I have called several dealers and they quoted from 12-20+ hours. For any of you Harley Dealer employees or mechanics out there, could you please give me a reasonable estimate as to what the hours are for this type of install. Thanks in advance.
This site is extremely informative as well as entertaining.
Old Nov 21, 2007 | 01:20 PM
2012UltraLimited's Avatar
2012UltraLimited
Default RE: Big Bore Stage II 103
I was quoted 10 hours labour ( $100/hour labour)for the 103" BB upgrade on an 07 Streetglide here in Vancouver, Canada.
Old Nov 21, 2007 | 03:57 PM
OregonRoadKing's Avatar
OregonRoadKing
I asked service manager about it and he said it would be about 8 hours of labor. Double that if you also want cams. Everybody I talked to said you should also change out the cams.
Old Nov 21, 2007 | 04:02 PM
DonnyI's Avatar
DonnyI
Experienced wrench can easily install big bore & cams in an 8 hour shift.
Old Nov 21, 2007 | 06:21 PM
dirtdobber's Avatar
dirtdobber
I spoke witht he service manager and their engine man. The engine man does only engines. They said $800 for labor. He said he could do it in 6-8 hours in everything goes as planned. He also said on the 07's-because it is a late model- has been very easy to do. They gave me a $150 discount on my 10,000 mile service because it was easy. No stuck bolts etc. The cost was $354 total.
I am planning on doing something but not sure exactly what I will do as of yet. If i do the 103 kit I want to change heads thats for sure.
Old Nov 21, 2007 | 07:39 PM
Road Hawg's Avatar
Road Hawg
They shouldn't charge you more then 10hrs. A dealer here in town is doing the SE103 for $1500.00 Parts,labor and dyno..
Old Nov 21, 2007 | 07:44 PM
tattoo13's Avatar
tattoo13
I am hoping to get the stage two kit with cams when I purchase a Road Glide for less than $1600,.
My goal is to get the bike, Stage II, a seat and backrest for list plus $2000 [:-]
Old Nov 21, 2007 | 09:52 PM
mhud's Avatar
mhud
The local HD dealer is running a winter special with the 03 kit and 255 cams for $1600 installed. He said it will not impact HD's warranty.
Old Nov 21, 2007 | 11:22 PM
Manish_Hawg's Avatar
Manish_Hawg
You know the after market kit will have more power but you still don't want to do one???? C'mon don't do the HD kit, do yourself a favor and just get some good cams. It will be close to the same result and way way way cheaper. I think cams are $250ish
Old Nov 22, 2007 | 02:48 AM
blackhog's Avatar
blackhog
6th Gear
15 hrs on my job. Do not use HTCC CNC Ported heads on an 08. They do not have the holes for the new front cylinder engine mount, my shop learned it the hard way. If you go with ACR heads don't forget about the wiring harness=more labor.
