Pipe size 84 - 94 95 - 05
Old 11-28-2007, 03:24 PM
White Knight 04's Avatar
White Knight 04
White Knight 04 is offline
Default Pipe size 84 - 94 95 - 05
What is the difference between 84 thru 94 mufflersand the 95 thru 05 is it pipe size or length, mount spaceing or what?????
Thanks in advance
Jer
Old 11-28-2007, 03:52 PM
SoCal_Pappy's Avatar
SoCal_Pappy
SoCal_Pappy is offline
Default RE: Pipe size 84 - 94 95 - 05
Different Size Exhaust Header pipes
Old 11-28-2007, 04:11 PM
White Knight 04
Just a guess, the older ones are smaller than the newer but how much????
Jer
Old 11-28-2007, 04:57 PM
Rininhoj's Avatar
Rininhoj
Rininhoj is offline
Just to let youknow, Hooker advertises their mufflers for '86-'07 FLH bikes as the same. I believe they all had 1 3/4" dia. head pipes. The only dresser style muffler I recall as being different was for the 1986 FXRD. The mufflers were shorter.
Rini
Offer void where prohibited.
Old 11-28-2007, 06:26 PM
White Knight 04
Ok thanks Rini,
I thought they were the same size but couldn't remember... I know the real earlier bikes had like 1 1/2 pipes but that was back in the 60's and 50's...
Jer
Old 11-30-2007, 01:30 AM
2007 ultra c's Avatar
2007 ultra c
2007 ultra c is offline
The early pipes fit together with a flange, the newer ones have a slip fit.
Old 11-30-2007, 09:40 AM
rizzo's Avatar
rizzo
rizzo is offline
Received 4,620 Likes on 2,094 Posts
I was just looking at the same thinglast night.
I have compared both early and late style and the diameters are the same. The flange at the end is about 1/8" and there is a thread on the forum that explains how a member cut off the flange on the early style to accept late model style slip-ons.
Old 11-30-2007, 09:46 AM
dougbk's Avatar
dougbk
dougbk is offline
When I put Rush mufflers on my 89 EG I had to cut the flange off the head pipes and the muffler for those years has a slightly longer neck on the muffler and they mount with the new torca clamps.
Old 11-30-2007, 11:28 AM
White Knight 04
I have done a search of the threads but can't find the one you are referring to ....Do you know what thread it is in....????
Thanks
Jer
Old 11-30-2007, 08:18 PM
notlost_nc's Avatar
notlost_nc
notlost_nc is offline
ORIGINAL: dougbk
The pipes are the same diameter. The header pipes on the 85-94 models havea flange at the end, just cut it off, remove as little pipe as possible and slip any newer style mufflers on. I'm using the stock H-D clamp. On my '84 I had to change the rail under the saddlebags to accept the new mount. There's really nothing to it. The only tools you'll needare a hacksaw andafile.
Wmitz
Milwaukee Eight (M8)
11-13-2016 03:56 PM
dontdropit
2014-2023 Touring Models
15
05-06-2016 09:34 AM
Scuba10jdl
10-03-2010 10:31 AM
Certified Drunk
06-25-2010 09:50 PM
madmax23
Exhaust System Topics
02-18-2009 02:07 PM
Quick Reply: Pipe size 84 - 94 95 - 05
