Rear Brake Squeel
Old Dec 9, 2007 | 09:59 PM
SILVERTEX's Avatar
SILVERTEX
Default Rear Brake Squeel
I posted this on the tech forum also but I have a question about brakes. I just bought an "08 Ultra Classic and as I slow down, the rear brakes squeel or screech. Was just wondering if it is because they are new and need a few miles to break in or if an adjustment could be needed. Wondering if anyone else had this happen or if it is typical.
Old Dec 9, 2007 | 10:03 PM
SteveO's Avatar
SteveO
Default RE: Rear Brake Squeel
My 08 Ultra SE3 had the same problem, it's typical on the 08 bikes, itshould go away after a few hundred miles.
Steve
Old Dec 9, 2007 | 10:14 PM
GlennsGlide's Avatar
GlennsGlide
HI guys
My 2006 EGC has had the rear brake squeal since new and still has it 13,000klms later. I'm hoping that when I need new pads I'll go with another brand and cure the sqealing.
Glennsglide
Old Dec 9, 2007 | 10:39 PM
adlerx's Avatar
adlerx
I have read about MANY of the 08's having this problem, mine has it. Really though, it's the only complaint I have heard anyone make about an 08.....
Old Dec 9, 2007 | 10:42 PM
vette's Avatar
vette
my 08 ultra squeals also. but seems to be getting not as bad with more use.
Old Dec 9, 2007 | 10:57 PM
Hoffy's Avatar
Hoffy
I posted this same question about a week about ago. A member said its the cheap brake lining they used with the upgraded brembo brakes and to switch to lyndall pads to get rid of the squeak. I think I will just wait untill my street glide pads need to be replaced from wear, than change brands.
Old Dec 9, 2007 | 11:31 PM
Jsans's Avatar
Jsans
My 08 Street Glide has 1400 miles and the rear brake still squeeks as I slow down.
Old Dec 9, 2007 | 11:32 PM
pkenyon1's Avatar
pkenyon1
Mine are exactly the same after 1500 miles
Still waiting for the dealer to fix them!
Old Dec 9, 2007 | 11:35 PM
reddfinn's Avatar
reddfinn
My 08 Ultra has 2500 miles and the brakes still squeel. I ignore it. Will change the pads sometime.
Old Dec 10, 2007 | 12:30 AM
captjon37's Avatar
captjon37
Common problem with 08s. My 08UC does it so i turn the radio up. Going to worry about it when i need new pads. Seems to be getting less as i put the miles on.
