RG Owners-Lower Fairing Install/Fork Baffle
Old Dec 16, 2007 | 12:02 AM
mhud's Avatar
mhud
Default RG Owners-Lower Fairing Install/Fork Baffle
The directions for installing the lowers I received today directed to remove the fork baffle for rider comfort. I assuming this is for air movement. Just curious if any of you removed the baffle and if so what was the result.
Old Dec 16, 2007 | 01:04 AM
buttman's Avatar
buttman
Default RE: RG Owners-Lower Fairing Install/Fork Baffle
I left mine on to start with. I found no real difference for me, but my backseat rider did notice a real increase in heat. The motor definitely ran hotter. After I pulled the baffel off, my passenger was happier and so was the engine. There was a noticeable difference in engine temps, but I don't think it was to bad for the motor. It was about 10 degrees during the summer.......that was when I decided to put the oil cooler back on.
Old Dec 16, 2007 | 07:51 AM
swipter's Avatar
swipter
I bought a fork baffle for the buffetting. If you don't have issues with that, chuck it.
Old Dec 16, 2007 | 09:23 AM
seldyn1's Avatar
seldyn1
I notice with the baffel off I got more air up under the fairing which seemed desireable in warm weather. Once it gets cold I reinsstalled and felt there was less cod air up around my face. I think there is a difference and depending on temp add or remove.
ejvette
Dec 20, 2013 04:14 PM
dlongo8241
Mar 2, 2012 05:47 PM
street_glider
Aug 3, 2010 06:54 PM
1mrbill
May 13, 2008 08:24 PM
rkc9999
May 18, 2007 02:04 PM
