It's FREEZING outside soooo.....
Old Dec 16, 2007 | 03:07 PM
  #31
powdercoater's Avatar
powdercoater
Default RE: It's cold outside and wondering where do I...
ORIGINAL: Rocket Jockey
According to the HD Service Manual, there is no easy method to replace the anti-freeze. It states, "....remove PHreeze plugs from outboard cylinder head, located next to piston return spring inspection window. Using the glug method, add anti-freeze until visible while laying horizontal, bike on jiffy stand, closing left eye while lying on right side, unless you are googly eyed then just pour it until it overflows."
I suggest taking in to a cerified Harley Davidson Service Center,
RJ
Off to the shop to watch football and wrench on the bike......what could be better.
That was a good one! I'm gonna laugh over that one all day.
Old Dec 16, 2007 | 03:09 PM
  #32
kart11's Avatar
kart11
Forgot one more thing ....dont forget to change the winter air in your air shocks too!!!
Old Dec 16, 2007 | 03:13 PM
  #33
timebandit60185's Avatar
timebandit60185
Default RE: It's FREEZING outside soooo.....
you use a grease gun the nipple is on the neck in the summer you put grease in instead of 50/50antifreeze
Old Dec 16, 2007 | 03:47 PM
  #34
tarheelrdr's Avatar
tarheelrdr
Pull tab on favorite barley pop, open mouth, guzzle quickley, repeat 6 to 12 times or as required for time allowed. Winter may require more frequent applications.
Old Dec 16, 2007 | 04:26 PM
  #35
choochoo's Avatar
choochoo
Well what brand of antifreeze are you using?
Brand I use calls for full strength straight from the bottle.
But I have been known to dilute it sometimes.
Prefferred brand and location of fill opening?
Jack Daniels and open mouth!
Old Dec 16, 2007 | 04:42 PM
  #36
troutbum1971's Avatar
troutbum1971
where is my fluxcapacitor? my fill light keeps coming on?
  #37
CREEPSHOW's Avatar
CREEPSHOW
Hope the V-rod guys don't see this thread!
[sm=chattypair.gif]
Old Dec 16, 2007 | 04:53 PM
  #38
curlydee's Avatar
curlydee
Be sure you use the orange stuff the green will damage the lower end of your motor.
Old Dec 16, 2007 | 05:20 PM
  #39
sleepman54's Avatar
sleepman54
Man talk about cabinfever. Guess I better check my coolant it's been in the 80's down here.
Old Dec 16, 2007 | 06:05 PM
  #40
Dalton's Avatar
Dalton
I asked the parts guy at HD about this. He told me that if I don't use genuine HD Antifreeze, and have it put in by a Genuine HD Service Tech, it will void the warranty.[:@]
Do I dare take a chance and do this work myself?[sm=escape.gif]
