Stablizer???
Old Dec 17, 2007 | 08:48 AM
Rocco18's Avatar
Rocco18
Default Stablizer???
True Trax, Traction Master, TXR ??? Which one are you using? Why? How much? Where did you get it? How much of a difference? Do you think it was worth the money? Any other feedback you have is apprecitated!!
Old Dec 17, 2007 | 08:59 AM
xxxflhrci's Avatar
xxxflhrci
Default RE: Stablizer???
None for me. My personal bike is a RKC. My work bike is a FLHPI. I haven't seen the need on either bike.
Old Dec 17, 2007 | 09:31 AM
TexasBowhunter's Avatar
TexasBowhunter
Ride str-8
Old Dec 17, 2007 | 09:47 AM
voodoodrug's Avatar
voodoodrug
was interested at first,then got confused,then thought at this point im fine w/out it.
Old Dec 17, 2007 | 10:52 AM
wldbill's Avatar
wldbill
ORIGINAL: TexasBowhunter
Ride str-8
DITTO the RideStr8
Old Dec 17, 2007 | 01:15 PM
Roofuss96's Avatar
Roofuss96
True Trax, Traction Master, TXR ??? Which one are you using? --- None , had one on my '02 FLHTC and wasted $400. Make sure the bike is in "spec' alignment and rear wheel wise, good shocks, all bushings { swaybar, etc. }and mounts are good, steering tight, and ya have a good tires set at the right psi..then if its not right maybe consider one of these...
Old Dec 17, 2007 | 01:23 PM
izzi's Avatar
izzi
TRUE TRACK[sm=signs003.gif]
Old Dec 17, 2007 | 01:33 PM
Mississippi Bagger's Avatar
Mississippi Bagger
ORIGINAL: Rocco18
Ridestr8. Used this one because it did not reduce ground clearance. Got a discount at http://www.axiomcycles.com/pages/ite...temsection=528
Have noticed a significant difference.
Yes, tire pressure is correct, shock pressure is correct, rear wheel alignment is correct, bushings and motor mounts are good, steering tight. But it was still mushy and wallowed. With the ridestr8 it is much improved.
Old Dec 17, 2007 | 01:50 PM
jag1886's Avatar
jag1886
RID-STR8 works. I bought mine on EBAY. It was out of the package butit had never been installed.
Paid $275.
Old Dec 17, 2007 | 02:26 PM
biz44's Avatar
biz44
I am still on the fence. I have yet to experience the rear steer or whatever people want to call it since this 08' is my first bagger. Most of the riding I do on my SG is highway, or slow back roads. NJ is far from canyon country.
