GW vs Ultra Classic
Old Apr 24, 2008 | 08:38 AM
  #141
racklefratz's Avatar
racklefratz
Default RE: GW vs Ultra Classic
ORIGINAL: themensh
The cons of a Goldwing as I said before are maintenance. Some areas that require maintenance can take time to get to. Panels/seat and radio/stereo have to be removed to get to common areas.
And on a HD, you don't have to remove any "panels" to get to stuff? What about the seat? Don't you have to take that off to get to the battery or ECM? I replaced a headlamp bulb on my Wing yesterday by simply reaching behind the fairing. To do the same job on my Ultra Classic, the batwing fairing has to come off. Better deal, right?
Need to check a fuse? Remove the left saddle bag (not as easy as a electra glide).
Total and absolute BS. You get to the fuses on a Wing the same way as you do on a Harley. They're behind the left side panel. Get a clue.
Ask a salesman to show you the airfilter on a Goldwing (1500 OR 1800)....watch the look on his face.
Right. He'll explain it, then his face will light up and he'll smile and tell you that Wings's need maintenance so infrequently, it's basically a non issue. Again, get a clue.
You want to talk crap about Honda fine........know what you are talking about first....dick.
I happen to own both, and I do know what I'm talking about. Where'd you get all that BS about Wings, your HD salesman?
Old Apr 24, 2008 | 09:06 AM
  #142
racklefratz
ORIGINAL: Thunderchild
pulled up at a restaurant, got off and walked in...sat down and somebody askes...."is that a Harley?" and Iproudly say "yes." this has happened several times. not once have i ever been asked..."is that a Gold Wing?"
On my GL1800, I've pulled up [wherever] and been asked, "What kind of motorcycle IS that; I didn't know they made motorcycles that pretty!" It's happened several times.
Old Apr 24, 2008 | 09:21 AM
  #143
racklefratz
ORIGINAL: GaryWayne
I don't think its fair to compare the power of the 2 though. The Wing is a 6...it should run better than a 2 cylinder.
Current model Electraglides have only 248cc less displacement than GL1800s (1,584 vs 1,832 cc). Run the numbers and you find that a Goldwing makes 69% more hp (118 vs about 70) with only 16% more displacement. That's where the real story is. It's not just the number of cylinders.
Old Apr 24, 2008 | 09:47 AM
  #144
user 8373900's Avatar
user 8373900
The ECM is behind the right side cover on my 07 UC,probably is on your 08 if you have one, and I would GLADLY pull a front fairing to change a bulb, (although I'm not sure you have to), I can change my air filter in 10 minutes , how long does it take on your Wing?It was a 2+ hr job on my 05 Wing.
Mark
Old Apr 24, 2008 | 12:42 PM
  #145
Silvertip's Avatar
Silvertip
Your wife will thank you if you buy her a Milwaukee Vibrator.
Old Apr 24, 2008 | 02:07 PM
  #146
Bluerose
Guest
Posts: n/a
ORIGINAL: racklefratz
ORIGINAL: Uncle Scrooge
Leaving aside all the intangibles about style, soul, etc.,the GW still has two big liabilities for me:
1) the "sit up and beg squirrel" driver's seating position (don't become so fixated on passenger comfort that you lose sight of driver comfort).
2) thevery small amount of trunk and saddlebag space (look carefully at this and you will seewhy most Wings are pulling trailers).
I don't know how you build a bike that big and still have these liabilities. By the way, with a little looking you can find a basic Wing for much less than MSRP.
I own both, and I'll tell you what, driver/passenger comfort are somewhat subjective in terms of ergonomics, but you're just wrong about trunk/saddlebag space. My Ultra Classic has nowhere near the carrying capacity my Goldwing does. I go to the grocery store on the Wing rather than the HD for precisely that reason.
OK gonna have to stop that part of your ranting. I actually do have both '08 bikes sitting in my garage. The rear tour pack of the Ultra has more room then the Wing. I can put both full face helmets and have enough extra room for a good sized jacket in the Ultra but CANNOT do thatin the wing. The side bags are about equal but I don't have to buy somethig to hold my stuff in my Ultra when I open the bag. All in all the Ultra bags are more functional...
Rider passenger comfort are subjective, but the stock seat on the Ultra did beat the GW slightly (doesn't force your family jewels into your throat on the ultra)....neither are good for more then 50 miles even with the useless seat heater on the wing.
Hubby hasn't done any service yet but is getting ready to install the CB soon so we'll see how much it takes.
Old Apr 25, 2008 | 12:15 AM
  #147
Mountainkowboy's Avatar
Mountainkowboy
1 screw to remove seat and you need to check your facts idiot, the headlight comes out the front of the fairing to change the bulb on a HD batwing. 1 screw to remove the trim ring, and 3 screws to remove the headlight assembly to change the bulb.
And yes I have owned both, as I've said before............try to get parts in 10 years for your GW. Honda is only interested in selling you a motorcycle, not keeping it on the road in the future. You'll have to buy the "latest and greatest" from them. I still can get parts for my 50 year old HD at the dealer.
Old Apr 25, 2008 | 01:30 AM
  #148
drrandall1's Avatar
drrandall1
Gold wings are gay
Old Apr 25, 2008 | 02:01 AM
  #149
big cahuna's Avatar
big cahuna
you guys do realise this post is over 5 months old, and that guy has probably bought a bike of some kind by now.,,,
Old Apr 25, 2008 | 07:01 PM
  #150
racklefratz
ORIGINAL: ONEDOWNAND5UP
Don't know what you mean by "if you have one", I thought I made it crystal-clear I own an 08 UC. And, the "ECM" is NOT "behind the right side cover" - it's under the seat. OK? We clear on that?
Well, be sure, you will "have to". I've had my batwing fairng off several times; that's where the headlight connector is. Maybe you need to get a little better informed.
I can change my air filter in 10 minutes , how long does it take on your Wing? It was a 2+ hr job on my 05 Wing.
Who really cares? C'mon. Tell you what - I'm at a point in my life that frankly, it's unimportant to me how long it takes to change an air filter on *ANYTHING*.
I own tools, and I work on whatever I feel like working on, but when it comes to my bikes, I change the oil, and that's about it. If it takes the tech "2 hours to change the air filter", along with all the other stuff he's going to do with the Goldwing's top shelter off at the VERY INFREQUENT SCHEDULED MAINTENANCE INTERVALS, so be it. The point is, it simply does not have to be done that often, and, to me, it's a non-issue. You want to let it eat at you, go for it.
