Serious question about engine builds
Old Dec 22, 2007 | 02:38 PM
chornbe's Avatar
chornbe
Default Serious question about engine builds
Let me ask a question regarding all these big-bore and performance builds going on.
In these typical (and by the sounds of them, not-so-typical) builds going on, how many people are changing the rev limiter settings and using cams and valve springs that increase the potential operating RPM, or are change gearing as part of the build?
I ask this because unless you increase the RPM operating range (or gearing), you're not really increasing the *theoretical* top speed, only the rate at which you can achieve said top speed.
Old Dec 22, 2007 | 02:43 PM
lil_gmac2's Avatar
lil_gmac2
Default RE: Serious question about engine builds
All engine builds will get some type of Rev limiter, cam and gearingchange. I so command that most people do mention it anymore. It's like needing your keys to open your start your car.
Old Dec 22, 2007 | 02:45 PM
chornbe's Avatar
chornbe
Cool. Thanks. Rarely hear about people's new rev-range, etc.
Danke.
Old Dec 22, 2007 | 02:57 PM
acedantinne's Avatar
acedantinne
Read alot about engine rebuilts. Cams? Have not read any valve springshims added any where? Pretty much throw cam in and go. Most never read the instruction on proper valve spring rate.
This will set off a flurry of pissed off backyard mechanics! There is alot of need to know info to get the job done right! Longer duration (valve opening) more pressure needed to close valve. everything (changes has its limit). Set valvues.
If you do not know what your doing? seek out the professionals.
Next subject=ring end gap. just not meassured at top of cylinder.
Old Dec 22, 2007 | 03:14 PM
chornbe's Avatar
chornbe
ORIGINAL: acedantinne
Read alot about engine rebuilts. Cams? Have not read any valve spring shims added any where? Pretty much throw cam in and go. Most never read the instruction on proper valve spring rate.
That's the thing... I'm not building my engine. It runs fine. But I see all these folks talking about upgrades and builds and it *seems* that only half the job is getting done (my first career was as a mechanic), unless it's just implied at the builders are doing head work, too. Some of the labor rates I'm hearing, I just don't see how that could be. Would be interesting to see some of these more intense builds torn down after some miles and check valve seats and cam lobes and such.
Old Dec 22, 2007 | 03:25 PM
SpikeCT's Avatar
SpikeCT
Yes... When HQ does the headwork the valves and springs are changed along with improved guides. I have my rpm limit at 6200 and now and then hit it to quickly....
Old Dec 22, 2007 | 03:39 PM
PhilM's Avatar
PhilM
ORIGINAL: SpikeCT
Yea.... what he said! Just about anyone that does headwork will set the heads up for the build they are preparing the heads for. As far as "bolt-in" cams go.... well, that's why they are called "bolt-in". They are designed to worked well with stock components ~ including springs.
REV Limiter.... I also have my DTT set @ 6200. Most ignition upgrades suppport bumping the rev limt. As John said... it's surprising how quick you cam bang the limiter!
Some also change gearing. In 2002 (I think), the touring model harley's had a primary gear ratio change. It was 3.37:1 & changed to 3.15:1. It changed again in 07, but I do not know what it is now. Some folks like to swap the 3:15 bikes back to 3.37. It's not a bad mod on the stock'ish & milder builds. Personally, my feeling is that if you have a motor that will pull the gear, then the 3:15 is better ~ but that's just me.... & mine will pull it.
Old Dec 22, 2007 | 03:52 PM
Tripper's Avatar
Tripper
ORIGINAL: chornbe
The only time I hit the redline on my build is going thru1st and2ndgearsI can make my state's maximum speedlimit by 3rd.
But, I'm only interested in how fast I may achieve said speed limit.
Old Dec 22, 2007 | 03:55 PM
jeepster09's Avatar
jeepster09
Set mine at 6800 RPM
Old Dec 22, 2007 | 03:56 PM
tarheelrdr's Avatar
tarheelrdr
I was thinking of going to 3.37 gearing, but the more I ride it , the more I realize I don,t really need it, 113" w/Headquarters parts is just fine.
