I downsized to a 6x12 big mistake, I know its possible to get 2 bikes in but not on my watch, not worth the stress if one tye lossens up. Just my opinion!
You can haul the 2 bikes in the 6X12. Pull the Ultra up front on the left and then run the sporty up staggered on the right. Always use 2 tie downs per side on each bike just in case one might brake or come loose.
I run a 6x12 Haulmark motorcycle designed trailer, which is 79" wide on the inside. I can fit two baggers staggered with no problems at all. Rule of thumb should be 60/40 weight distribution, with 60 being towards the front.
My wife and I both ride EG standards. We bought a Pace Legacy 7X14 TA. It is a drop axle trailer so loading and unloading is a breeze. We added 6 inches to the height and can stand in it perfect. It is still quite a bit lower than most and only about 6 to 8 inches above the roof of my Dodge Quadcab. http://www.paceamerican.com/trailers/legacy/ Anytime you try to trade anything you can expect the shaft. Just my .02
I did it a couple of years ago with my Ultra, I had to remove the bags and tour pack and it was still tight.
I have since sold my trailer, it was just not worth the trouble of breaking down the bike when we both ride.
Tounge weight was a big issue and had to play around a bit with it, I had a side door which made it easier to load, Ultra was up front and to the side and my wifes sporty went in last and to the left
Rich
I am no expert but 6' is 72" I think that your trailer must be a 7' which is 84", minus the side walls, probably close to the 79"
Rich
He must have meant '7x12 Haulmark' (not sure if they make one). I have a 6x12 and I am 5'11" tall and I know I can't lay down side to side. Please don't ask how I know. lol
I have a 6x12 enclosed trailer and I run the sportster up front on the left and the roadking to the rear on the right. This lets me use the front right and left rear corners for gear. I run the sportster up front because I have a 4ft extension (haul a Lance 1181 camper).
I traded the roadking for an ultra so it shouldn't be that big a difference to accomodate the fairing.
I can also fit both in the back of my truck with the tailgate up, nothing touches.
