Torque your bike?
Old Jan 6, 2008 | 05:54 PM
ezlife's Avatar
ezlife
Default RE: Torque your bike?
ORIGINAL: BOARGAURD
Always, there is a reason the book has a value printed in it.
What he said!
Old Jan 6, 2008 | 06:21 PM
TickTock's Avatar
TickTock
ORIGINAL: oley55
good thread here. now that we're into it, is the high costname brand torque wrenches justified, or will acheapo Chin-Tech something or other serve OK for the occasional weekend wrench turner?
I have a sears for foot pounds and an expensive Matco for inch pounds. I figure a footpound might be within tolerence, but I wouldn't trust a cheapy with inch pounds.
And I don't care who you are, you can't "feel" the proper torque setting.
Old Jan 6, 2008 | 06:32 PM
Tinkermc's Avatar
Tinkermc
my scoot is still under warranty but I do the wrenching. So I always do so that could not be an issue if I need warranty
Old Jan 7, 2008 | 07:26 AM
redclassic's Avatar
redclassic
ORIGINAL: TickTock
ORIGINAL: oley55
Agree, looking to buy a Snap On for In Lbs, ( CDI makes the Snap On stuff ) and currently have a new Kobalt for Ft Lbs but may get a new " Split Beam " wrench by Precision Instruments. They say that with the split beam type the pressure you apply breaks free when you hit your torque setting, which will prevent over tightening.
http://www.emaxaction.com/index.asp?...amp;ProdID=425
[IMG]local://upfiles/46272/1FDC6E04CBB44C978AC9B0B6A820D1F4.jpg[/IMG]
Old Jan 7, 2008 | 08:06 AM
starbuck's Avatar
starbuck
Engine work only pretty much Heads, Valve covers etc etc...Air Cleaners, Bars, Exhaust, Drain plugs, No...LockTight and the elbow.
Old Jan 7, 2008 | 08:48 AM
allen.m's Avatar
allen.m
Allways!
Old Jan 7, 2008 | 08:58 AM
iclick's Avatar
iclick
Almost always by the book, especially with bolts going into aluminum, which is almost everything. Always torque axles to spec. If I don't torque I'm aways careful not to overtighten.
Old Jan 7, 2008 | 09:06 AM
petemac's Avatar
petemac
I always do. Why take chances when it's an easy thing to do.
Old Jan 7, 2008 | 09:53 AM
89FLHT's Avatar
89FLHT
When I'm in the engine, trans or primary or when I'm installing the front or rear wheel the torque wrench is out, for the rest, I do by feel.
Old Jan 7, 2008 | 09:59 AM
jdtest's Avatar
jdtest
Always, if the book says to.
