Antenna Question
Old Jan 6, 2008 | 07:06 PM
harleyhoots's Avatar
harleyhoots
Default Antenna Question
I know this has probably been discussed. But I was curious as to how good a Harley antenna will work cut down add put inside my fairing with the coax coiled up. I have the Hells Foundry set up with an amp. I've tried the Dakata Digital antenna and it doesn't work with the amp.
Old Jan 6, 2008 | 07:10 PM
eglidetrike1's Avatar
eglidetrike1
Default RE: Antenna Question
Won't work to good tried it, how about just putting a shorty antenna on?
sewerat's Avatar
sewerat
I had cut mine down and it worked fine, but then what I did was go to the local auto parts store and buy one of those $12 rubber universal mount antenna's and tuck it up onside the fiaring attached to the radio and it works just fine, I then took the mount off the back and just tucked the rest of the wire up undr the seat someplace, no need to pull it all out and remove it.
Old Jan 6, 2008 | 07:28 PM
Pelonz's Avatar
Pelonz
Heard of guys putting the "rubber duckie" type antennas inside the fairing. Personally I haven't tried it but do run a "tune trapper" that is not powered under the fairing. Got it off e-bay I think
Old Jan 6, 2008 | 07:42 PM
SoCal_Pappy's Avatar
SoCal_Pappy
I went with the Tune Tapper hidden antenna.... Works well for me... But I listen to XM 90% of the time...
Old Jan 6, 2008 | 08:13 PM
07blackcherryflhx's Avatar
07blackcherryflhx
Does the tune trapper have to have aux power run to it?
Old Jan 6, 2008 | 08:17 PM
harleyhoots
Does the tune trapper work with a amp?
Old Jan 6, 2008 | 09:03 PM
big_al's Avatar
big_al
I cut mine to about 14 inches and it works perfect, however miami florida is flat. I listen to my ipod 95% of the time and the other 5% I listen to cd's....
Old Jan 6, 2008 | 09:29 PM
pab's Avatar
pab
Cut mine to about 16", and works fine in the hills of Tennessee.
Old Jan 6, 2008 | 09:40 PM
rapz's Avatar
rapz
I've got the short J&M and they are very good.
