I have installed a usedtour pak that once had speakers on my '05 RG. I don't want to install new speakers (right now!) and the existing holes are unsightly. Does anyone know of plugs made to fit these holes? Maybe someone has used another method for temporary filling of these holes.
Get black plastic bags and cut it to the size of the speaker grill assuming you have the grills and put your screws through the plastic then put them back on... Walla no holes to see into and you will never go fast enough to rip the bags if you use the leaf type bag...Jer
Find a ACE HARDWARE or your local store... They'll have soft rubber plugs that will fit - Or you can try small bolts with flas washers and put on Chrome Caps covers
I've got little black plastic plugs in mine that the dealer put in...go to a Lowe's or similar and in the hardware section in those big drawers of misc stuff they have the plugs...black ones,chrome ones ect..measure the diameter of the holes and go....
Thanks all. I guess I wasn't very clear on my initial post, there are no speaker pods. The holes I am wanting to fill are the ones the pods are mounted thru. Some read my mind anyway and I will probably try to find some rubber plugs from Lowe's or Home Depot. Any other ideas?
I'm looking for the same kind of small plugs to fill the mounting holes. Lowes and Home depot did not have them so I'm going to try the small hard ware stores down town.
