Removing Scratches
Old Jan 9, 2008 | 08:20 AM
biz44's Avatar
biz44
Default RE: Removing Scratches
You always should start with the least aggressive product, and work your way to more and more aggressive as the results dictate.
The PC 7424 is a outstanding tool. Its a random orbital polisher/buffer, and is very forgiving for the novice user, but can still "burn" the paint on irregular surfaces if not used correctly. I have found that on motorcycles its not actually needed....it is a help and more of a help on touring bikes with baggs and tour pack's.
As for what product I like on black colored bikes/cars. Well I like the 3M line....either fine cut compound, Imperial Hand Glaze, or their "swirl mark reducer/remover for dark colors". The Maguires Scratch-X also works well....but the product I like best is called Liquid Ebony, and you can get it in a auto body supply shop. Depending on the location, severity, and color in question I make my choice as to what product I will use. Just remember to use a good sealer or glaze, and then a good wax to finish it. ALWAYS use the highest quality 100% cotton terry cloth detailing towels you can find......I have found the ones that are sold at www.zymol.com are very very good, but any detailing towels should be used ONLY for detailing, and rotate the towel often...also you should only use them to remove product....not to apply it. When you wash them do not use any fabric softener or dryer sheets...they will cause most products to leave a haze behind after final buffing, and then you have to do the job over.
I highly suggest you visit a few detailing forums, and ask plenty of questions before you touch anything.....if you dont you can cause more damage than what you have already.
Old Jan 9, 2008 | 08:58 AM
BlkSilverado's Avatar
BlkSilverado
I've used the HD scratch remover, and it works great. Apply a small amount to the scratch, and work it with a clean micro fiber towel in the direction of the scratch. Learned about it at the detail area in Rapid City from a HD rep. I had a pretty deep scratch in the top of my gas tank that disappeared in about 10 minutes.
Old Jan 9, 2008 | 09:46 AM
vinnieee's Avatar
vinnieee
ORIGINAL: biz44
Depending on the location, severity, and color in question I make my choice as to what product I will use. Just remember to use a good sealer or glaze, and then a good wax to finish it. ALWAYS use the highest quality 100% cotton terry cloth detailing towels you can find......any detailing towels should be used ONLY for detailing, and rotate the towel often...also you should only use them to remove product....not to apply it. When you wash them do not use any fabric softener or dryer sheets...they will cause most products to leave a haze behind after final buffing, and then you have to do the job over.
I agree 100% - I prefer to use hand buffing first.
Old Jan 9, 2008 | 09:54 AM
Rob2002's Avatar
Rob2002
MOCO's clear coat is crap.
Got the '06 vivid black ECG and spend way too much time buffing scratches.
And yes, I do know what to do and what not to do...............
Scratch-X works pretty good for me but I'm willing to try something new.
Old Jan 9, 2008 | 02:20 PM
backnasaddle's Avatar
backnasaddle
Steve, I agree. I have the same basic equipment. I've also had good luck on mhy black cherry with McGuires Sworl Free Poish and a light cut compound. I don't recal the name of that one off the top of my head. Keeps baby looking smooth!!!
Old Jan 9, 2008 | 02:29 PM
IBHarley's Avatar
IBHarley
I use DuPont micro finishing compound works well with either hand or electric polishing and finish off with a glase
Old Jan 9, 2008 | 02:57 PM
rjmac53's Avatar
rjmac53
Great info
Old Jan 9, 2008 | 03:26 PM
big_al's Avatar
big_al
I am fortunate that I have a detailing dept and I have this particular guy that can get anything to shine literally perfect and remove any light scratch, haze, oxidation etcoff anything..
Old Jan 9, 2008 | 03:59 PM
Hardly Dangerous's Avatar
Hardly Dangerous
So big_al take the detailer out for a brew one day and get his secrets.
Old Jan 9, 2008 | 04:21 PM
Chuck1's Avatar
Chuck1
ORIGINAL: biz44
When you polish by hand, to removelight scratches , do you usesmall cuttingpads or a piece of a 6 in.one, like Lake Country's?? Or do you just use a foam or microfiber pad?
