LED Install
Old Jan 11, 2006 | 12:19 PM
daboys53119's Avatar
daboys53119
Default LED Install
I am thinking about installing some LED lights on the ultra and I know some of you have done this. Questions I have, can you wire them up to the accessory switch on the lower inner fairing? Also I want to just illuminate the ground underneath so which lights are the best? I have read a lot of info in this forum but nothing about pod type or individual or whatever is best for a particular application.
Old Jan 11, 2006 | 12:26 PM
FireHawk's Avatar
FireHawk
Default RE: LED Install
Well I didn't install mine, but the are the Electra Glow lights from HD and they are mounted on the frame (low) and above the engine heads. They do not come on with the ignition but wil a seperate switch that is mounted on the right side upper frame just below the saddle. The have an adjustable dial that you can set the lights to dim or bright or any in between. Thye light out the road underneath the ride pretty good. I'm planning to get the lighted floor boards as well later on.
Does that help?
BTW; the pic below does not show how well the glow lights light the street below as it was taken at dust.
Old Jan 11, 2006 | 12:41 PM
daboys53119
Sort of, I want more flexibility that the HD setup though and would rather not add another switch. What is the factory ACC switch for? And by the way I think your lights look great, tastefully done and not like a Christmas tree.
Old Jan 11, 2006 | 03:52 PM
fattizzi's Avatar
fattizzi
Go to this site and call the guys there. They are awesome to deal with and have great LED's.
www.nomagicneon.com
Old Jan 11, 2006 | 10:39 PM
MACK's Avatar
MACK
I USE KURYAKYN LIZZARDS. 4-6 WILL DO YOU FINE.YES YOU CAN HOOK TO THE NACCESSORY PLUG
slowrollin
2014-2024 Touring Models
17
Aug 12, 2017 11:25 PM
Missexeccph
Jan 25, 2017 09:51 AM
Rumblin
Sep 11, 2016 08:08 AM
timidones
19
Oct 17, 2015 09:44 PM
illinimeats
Product Reviews
39
Feb 7, 2007 01:55 AM
