Grip Glue
Old Jan 11, 2007 | 06:15 PM
hdjoe88's Avatar
hdjoe88
Default RE: Grip Glue
I switched out my OEMs last week for the H/D Nostalgics. I had some adhesive from a set installed on a previous bike and since the instructions called for it on the left grip, I used it.
Old Jan 12, 2007 | 12:00 PM
bob53's Avatar
bob53
I replaced my grips on my 99 Sportster. I did'nt need glue. The left grip was so tight getting it on that it was'nt going anywhere. Its been a couple of years now and still tight as can be.
Old Jan 19, 2007 | 10:31 PM
apachethunder03's Avatar
apachethunder03
Harley grips get secured with the handlebar clamps. After market need glue.
Old Jan 20, 2007 | 09:34 AM
ditch_dgr's Avatar
ditch_dgr
ORIGINAL: apachethunder03
Anyone know when they changed this, I had a 93 and a 94 Sportster, they both ahd the grips glued on. This is good news, the wife wants new grips on her Deuce and I was dreading the left one, I tend to lose blood when using sharp objects and cutting the old grip off didn't sound like fun.
Old Jun 8, 2007 | 06:46 PM
tckitt13's Avatar
tckitt13
OK Guys I just swapped my grips on my 2007 Road King out today and "whoa and behold!" All of you are right.The left grip was NOT glued on but the right grip was glued like a b*&tch to the throttle sleeve (I should have just bought a new sleeve). I cut and pulled and scraped and applied alchohol (to the grips not the gizzard) and cut and pulled some more and finally got what was left of the right grip off the sleeve. I cleaned up the sleeve and used 3M Super Weatherstrip Adhesive to the sleeve and put the new grip on. The left one was easy. Since I had already destroyed the right grip I decided that there was no use in trying to save the left one so I cut one slit down the grip and it came right off! I did use the weatherstrip adhesive on the left side as well since my replacement grips don't fit under the switch covers, just butt up against it.
One final note: Remember:
NOTHING IS FOOLPROOF TO A SUFFICIENTLY TALENTED FOOL!!!
Happy Riding
Old Jun 8, 2007 | 08:34 PM
dionne51's Avatar
dionne51
Purchased the Aeleron grips last year: HD instructions were to use HD adhesive on left, nothing on right. I ended up using a thin bead of silicone caulk to lock it in place and it is steady as a rock to date.
Old Jun 8, 2007 | 09:34 PM
Ram's Avatar
Ram
Grip Glue.
[IMG]local://upfiles/4133/96A3E674358140AF8B31718BF3BDCEDE.jpg[/IMG]
Old Jun 8, 2007 | 10:27 PM
kpb46's Avatar
kpb46
Maybe I have been doing this wrong for a long time but I use double side golf club grip tape. It is sticky on one side which you place on the bar. Then peel off the backing and wet the tape with mineral spirits. Makes the tape real slick. Slide on the grip and position. Let dry for a while. Once dry IT WILL NOT slip, move ,twist or anything else. If in doubt how to do this go to a place the reshafts clubs and he will have all the stuff and tell you how to do it.
P.S. You don't have to buy any expensive solvents for this process. Mineral spirits is fine
Old Jun 8, 2007 | 10:32 PM
Timex's Avatar
Timex
Silicone Adhesive.
Old Jun 8, 2007 | 10:55 PM
stich's Avatar
stich
Back in the days of racing dirt bikes, I was always replacing the chewed up grips. The old method we all used was just plain gasoline. pour it in the grip, slid it on and after the gas evaporated the gummy grip held tight. Never had a problem with slippage. Now I can't say for sure if this method will work for Genuine HD grips but hey, I'm about ready to change my grips and will keep you informed if my tried & true method still works.
Oh yeah, you have to use hi octane gas
