Has anyone ever done it
How much am I looking @?
thanks
Are you asking for the external brake lights or internal lights?
I added 2 Sylvania LED Spot Lights with custom (home made) brackets on the inside of my tour pack for a WHOPPING $17.98 plustax!!! Beats paying the HD price of $159.95 or 179.95 for their LED light kit.
They work great and light up the entire tour pack. I have used them this winter while riding back and forth to work, and for the price you can't beat it...Here's a couple of pictures of them mounted
There are numerous threads/posts on adding exterior lights to a tour pak. At the top of the page is the "search" function. If you type in "tour pak light" you get the following lengthy lists of posts:
If you go to the HD website and navigate to touring models accessories (lighting) you will find at least a couple of HD accessories and pricing for TP lighting. The two most common HD accessories seem to be the Ultra light bar (about 200); it's the same as the wrap-around light bar on the Ultra; and, the spoiler/LED (about 200).
You can also do a search for "Hoglite" which is an LED array that mounts under the TP which is about 50, and check squadfitters.com for additional LED arrays for mounting to a TP.
