Question about a build
Old Jan 29, 2008 | 11:13 PM
uniondog's Avatar
uniondog
Default Question about a build
Local shop has a re-worked set of 2007 heads - 1.900" int valves, 1.615" exh, milled to 85cc, ported, polished, new guides/seals, springs, I was told they can handle 630 lift cam.
NEW INFO FLOW - 1-31-2008
LIFT Water CFM
600 10" 168.55
550 " 165.34
Questions I have
What are they worth?
Will they work well with a 96" and Andrews 54H? Some other Cam?
Would they be better match for 103? 107 ?
Basically I would like some imput. If you were starting with an 07 Ultra ,the heads mentioned above and a 96" motor, D&D Fat Cat, TMAT and Zippers AC - What else would you do, if anything, to produce a solid - reliable running bike and what kind of tq / hp numbers could be expected?
Jim
Was told this would help with opinions on build:
Riding style- Cruise the back roads - Like the twisties - Ride the Big Roads to make up time on long trips 70- 85 mph for hrs sometimes. 50% + 2 up.
Respect
UD
Old Jan 31, 2008 | 03:19 PM
uniondog's Avatar
uniondog
Default RE: Question about a build
ttt
Old Feb 2, 2008 | 04:18 PM
miacycles's Avatar
miacycles
Woods cams, talk to Bob. probably a 6 or 6H and a good EFI tuner like a PC III usb.
Old Feb 2, 2008 | 06:27 PM
Harleypingman's Avatar
Harleypingman
Unless you can verify that the heads work well on the type of bike you ride and provide the performance you want, why consider buying them? There are lots of ways to shape ports and combustion chambers--some work well on baggers and others don't.
Jay Guild
General Topics/Tech Tips
Mar 28, 2018 10:26 AM
gearheadfmc
Oct 12, 2009 03:54 PM
mikestreet
Dec 9, 2008 07:42 PM
BigJfxdwg
Exhaust System Topics
Sep 11, 2007 11:47 AM
dog155
Feb 11, 2007 06:17 PM
