Front Axle Spacers Location Question
Old Feb 4, 2008 | 07:27 PM
avcaruso's Avatar
avcaruso
Default Front Axle Spacers Location Question
I took my front wheel off to mount a new Metzler MME 880 and did not not the orientation of the spacers thinking they were identical. When I went to remount I noticed one was slightly wider than the other, and one had some notches on it. Could someone give me the proper location of the spacers both location on the axle and orientation of these notches?
Bike is a 2006 Electra Glide Classic - Stock Cast Wheel - 16".
And yes.........I will be getting a service manual soon!
Thanks in advance!
Old Feb 4, 2008 | 07:38 PM
bob2002's Avatar
bob2002
Default RE: Front Axle Spacers Location Question
The short spacer goes on the brake pedal side,the three notches on the long spacer face the bearing on the gear shift (left) side.
Old Feb 4, 2008 | 07:53 PM
avcaruso's Avatar
avcaruso
Thanks Bob2002, you rock!
Old Feb 4, 2008 | 08:11 PM
bob2002's Avatar
bob2002
Glad I could help.
Old Sep 15, 2022 | 03:49 AM
CB333's Avatar
CB333
Stage I
Default Front end shakes.
Hello. I ride a 99 ultra classic. Recently I had right wheel bearing go out I changed everything out new. Amazed had no problem putting back together For bought a week was fine on it everyday. Then coming home on highway rode like was rubbing feeling. Then shook not constant. Tho. Went to take back apart see where I screwed up. But Cannot get axle slide out now. Ty in advance for any advice.
Old Sep 15, 2022 | 09:03 AM
MotoJockey's Avatar
MotoJockey
Although your issue is somewhat related to the original post, I would first, introduce yourself to the forum and tell us a little bit about you and your bike, then start a whole new thread concerning this issue your having. You'll probably get a better response that way instead of jumping on a 12 year old thread.........
Old Sep 15, 2022 | 10:27 AM
johndoe297's Avatar
johndoe297
Welcome to the Forums!
Agree with MJ. Start a new thread and post a pic of how you put things back together and you will get a better answer.
jakespade
Jun 12, 2013 06:47 PM
RPS1981
Mar 14, 2013 09:50 PM
sengle4
Feb 12, 2013 09:05 AM
HDCPL4PLAY
Feb 12, 2009 09:04 PM
truenorth
Mar 30, 2008 04:32 PM
