2012 Wheel on 2006
Old Mar 14, 2013 | 08:10 PM
RPS1981's Avatar
RPS1981
Default 2012 Wheel on 2006
My 2012 Street Glide front wheel/tire was delivered today. A zero mile take off. Gonna stick it on my 2006.
It has 25mm bearings installed, so my plan is to purchase a 25mm axle and correct spacers. That is, unless someone tells me it would be better to keep MY axle and spacers, and have 1" bearings pressed in.
Any advantage one way or the other changing axle/spacers versus bearings??
Old Mar 14, 2013 | 09:10 PM
DTTJGlide's Avatar
DTTJGlide
Do the 25mm axle & spacers, it's a direct bolt on since the lower legs haven't changed since 2000. The only way to do the 1" axle is to do all custom spacers including the inner axle spacer, if you own a machine shop it might be cheaper, but everything has to be perfect or you'll ruin the bearings.
Old Mar 14, 2013 | 09:30 PM
Lowcountry Joe's Avatar
Lowcountry Joe
A new 25mm axle at Lake Shore is about $75. Spacers will be very cheap there.
www.lshd1.com
Old Mar 14, 2013 | 09:49 PM
RPS1981's Avatar
RPS1981
Did not know that. Thank you for the very helpful reply.
Old Mar 14, 2013 | 09:50 PM
RPS1981's Avatar
RPS1981
www.lshd1.com
Thank you for the suggestion. Just placed my order from Lakeshore.
johnod
EVO
20
Feb 19, 2015 03:32 PM
FXDBISBOB
Nov 27, 2014 03:16 AM
HRK123
Aug 4, 2012 01:35 PM
St Glide
Oct 8, 2011 11:54 PM
HDCPL4PLAY
Feb 12, 2009 09:04 PM
