wheel swap question
Old Jun 12, 2013 | 11:56 AM
jakespade's Avatar
jakespade
Default wheel swap question
Have a 2000 fxd with spokes.
Want the 2006 and later 10 spoke mags.
Is this a direct swap (IE axle thickness, brake rotors and will the wheel fit the narrow glide?)
Or should I just swap the whole front end to make it??
Old Jun 12, 2013 | 01:48 PM
Gommee's Avatar
Gommee
Devil's Advocate
you need to compare axle sizes.
Old Jun 12, 2013 | 03:29 PM
jakespade's Avatar
jakespade
Right or pop out the bearing and spacer and refit. Which is why I'm asking. I don't want to buy and ship the rims if they won't work...
Old Jun 12, 2013 | 04:37 PM
Gommee's Avatar
Gommee
Devil's Advocate
Some of the older bikes had a 3/4" axle. An 06 should have a 1" axle. An 08 and later has a 25mm axle.
You need to look up the axle for each and see what the size is. If they have the same axle size, all you may need is new wheel spacers.
Old Jun 12, 2013 | 06:47 PM
jakespade's Avatar
jakespade
I think you're missing the meat and potatoes of the question...
1.) Will the mag brake set up work on an older 39mm front end?
2.) Will the wheel thickness for the space for the forks?
I know better than to not swap bearings spacers and so on.
NAILIT RK
Apr 3, 2015 09:13 AM
johnod
EVO
20
Feb 19, 2015 03:32 PM
Jerm83
May 24, 2013 04:28 AM
bigskyroadglide
Oct 24, 2011 02:51 PM
j1mmy
Classic
Feb 27, 2011 09:27 AM
