Turn signal conversion
Old Jan 18, 2006 | 11:42 PM
capt42a's Avatar
capt42a
Default Turn signal conversion
Hello All,
I just installed Harley's turn signal conversion on my 06 FLHT/I and wanted to tell everyone how easy it was to install. 1. remove left saddlebag. 2. remove screw that holds the passenger strap. 3. remove seat by taking screw located at rear of seat. 4. locate tail light wire coming through fender (only set of wires coming through fender). 5. disconect connector. 6. insert conversion connector between connections. 7. use zip ties to place the conversion module in a void under the seat. 8. swap out red lenses with the yellow turn signal lenses. 30 minutes to change everything, only problem I had was locating a space for the module.
capt42a
Old Jan 19, 2006 | 12:10 AM
jd_underdog's Avatar
jd_underdog
Default RE: Turn signal conversion
yes its tight under that seat
Rogue8Man
May 19, 2016 08:26 PM
bkbroiler
Jun 19, 2013 02:31 PM
Grumppa
May 22, 2013 08:49 PM
cmiller9219
May 21, 2010 10:58 AM
kato_159
Jul 16, 2007 05:53 PM
