Speakers, Amps & Ohms... Help
Yes you can put 4 ohm speakers on a 2 ohm amp but, you will have half the volume
If you want to, for some reason, consider how loud you can get a speaker to go with an amp of a certain power, recognize that power depends on the impedance of the speakers, so an amp rated for 100 watts at 8ohms is probably about 175 watts at 4 ohms (not quite double). Same vice versa. Take the speaker efficiency, apply it to watts of your amp into the impedance load, and you'll determine potential volume.
Here's reality: If you want max volume and high quality sound, you need an amp. If you're just replacing speakers for sound quality at reasonably loud listening levels, replace them with speakers with nominal impedance of anything greater than half the ohm rating of your factory radio amplifier and don't sweat it. You're only at risk of hurting your amp if you know you're pushing the limits of your amplifier, and its a toss-up whether you'd blow your amp or speakers first in that situation anyway.
OK everyone, get out your audio books and turn to chapter 3, today we'll be studying "The Inverse Square Law"......
Here's the skinny: Don't worry about ohms so much. Just go listen to some speakers, pick ones that sound good to you, try to match ohms the best you can, and don't push the limits of your radio's amplifier or speakers regarding volume. If you want more volume or better sound quality at high volume, add an amplifier.
I will explain this a couple of different ways.
first way:
ohms are resistance, amps are rated for X watts @ X ohms
therefore, double the speaker ohms half the wattage of the amp rating.
half the ohm speaker rating double the amp out wattage but produces a lot of heat in the amp.
second way:
An amplifier designed to put out 100 watts into4 ohms will put out 200 watts into2 ohms.(high heat)
An amplifier designed to put out 100 watts into2 ohms will put out50 watts into4 ohms.(low heat) half the volume, same distortion
Two4 ohms speakers wired in parallel (2 ohms total) would cause the amplifer to produce 200 watts.(high heat)
Two8 ohms speakers wired inseries (4 ohms total) would cause the amplifer to produce50 watts.(low heat but still heat)
High heat will kill and amp.
first way:
second way:
The output of an amplifier is not DC linear. Some amplifiers will almost behave the way you described above and others will not. Keep in mind there are three basic classes of amplifier: A, B, C. Each has its advantages. Most modern stereo amplifiers are class B, class A-B, or rarely class A. The problem with your power output assumptions is that you have a pure class A amplifier capable of very low impedance loads. This is highly unlikely in a automotive application because of the power consumption requirements. So in all likelihood an amplifier designed for a 4 ohm load is going to sound like crap into a 2 ohm load because it is most likely a high quality class B amplifier.
Amplifier classes:
A - High fidelity high power consumption
B - Trade off between Class A and Class C
C - low fidelity with good power efficiency
Would it be safe to say:
1.He wants to temporarily put in new 4 ohm speakers is fine but he may lose volume.
2. look at his amp see if it is 4 ohm it may solve his distortion problem by changing the speakers to match the amp.
3. Assume if he is attempting to hear his music at 70mph he needs it turned up. Therefore, matching the ohm rating on the amp to the speakers is important.
4.If he is going to use it around town at 25mph then using his amp at mid-range the ohm rating is less important.
5. Next time someone asks a simple question, more than likely will not want an in-depth answer or even really understand it just adding to confusion, short 2-3 word answers are better.
first way:
second way:
Tlb - I agree with you. Good advice. But cut power in half, volume goes down 3db. That's barely noticeable. Not half. Otherwise, combine your response and my skinny one, and I think we've got it solved.
