Low Fuel Light
Old Feb 10, 2008 | 04:08 AM
Kennyv's Avatar
Kennyv
Default Low Fuel Light
This winter I put ape hangers on my 07 RK I ran all the wiring inside the bars. Since doing that my low fuel light will not come on. Is the because I had the battery disconnected? If so is there someway to reset this? Appreciate any help.
Old Feb 10, 2008 | 05:13 AM
dog155's Avatar
dog155
Default RE: Low Fuel Light
Should have nothing to do with it.Handlebar wiring is seperate.Maybe drain the tank and see if it will come on.There may be a bulb you can replace.
Old Feb 10, 2008 | 07:59 AM
Thundercloud's Avatar
Thundercloud
Kenny,
Mine was doing the same thing with the tank full. I found by searching on here that there was a Service Bulletin put out by HD in 2004 for EFI models that this could be an issue. The only fix they said was to cycle the ignition switch on then off. I tried that about 20 times and nothing. I took the bike out and rode about 10 miles and it went off. I haven't had a chance to run this tank of gas out and see if the low fuel light comes on when low and does not come back on when I fill up again, but I am hoping it has reset itself.
Let me know if you find out anything different.
Good Luck,
TC
Jack Straw
Nov 29, 2016 04:41 AM
minesweeper
Mar 28, 2011 07:43 PM
Styx117
Exhaust System Topics
Aug 21, 2008 06:23 PM
Thundercloud
Feb 4, 2008 10:46 AM
Jetstream
19
Mar 2, 2007 09:43 PM
