Two audio inputs
Old Feb 21, 2008 | 06:48 PM
jpetty's Avatar
jpetty
Default Two audio inputs
The iPod has been plugged into the aux jack, and works great. I added a Zumo last fall and want the audio directions. I know there are devices to accept two inputs and provide one output. What are you guys using. It would be easy to use the Zumo's mp3 player, but I gotta have my iPod.
Thanks
Old Feb 21, 2008 | 07:51 PM
socalmoe's Avatar
socalmoe
Default RE: Two audio inputs
Interesting question, never herd of such thing. How is the radio supposed to select which input to put out, either the output is the ipod or the Zumo.
I have a splitter into my aux in my car radio for my Sirius and my Ipod but only one is on at a time into the Aux jack.
Old Feb 21, 2008 | 09:06 PM
Retired_Ted's Avatar
Retired_Ted
Check out CYCLEGADGETS - the Kennedy Corporation has a gadget that will do what you want.
Old Feb 21, 2008 | 09:22 PM
atexn4christ's Avatar
atexn4christ
The Zumo 550 is a mp3 player.
Old Feb 21, 2008 | 09:51 PM
RADLINE's Avatar
RADLINE
I use my ipod mini and my Zumo 550 for tunes and driving directions.
I installed a cable for each, so the one not in use is curled up and around the throttle cable.
I just switch cables for which device I want to use.
Works ok, but having one cable and a switching device would be nice.
I'll check out that Cyclegadgets unit - Thanks for the heads up on that.
I've ordered many things from them and they are a good company to deal with.
Old Feb 21, 2008 | 10:09 PM
chappy's Avatar
chappy
Hi, here's a link http://www.cvoharley.com/smf/index.php?topic=7674.0
It's a long thread, but it will answer all your questions with easy to follow instructions and with pictures.
Good info for theHarley older and newer radios
gives feed back for the use of 2 audio in at the same time with a Zumo.
Who could ask for anything more?
chappy
ORIGINAL: jpetty
Thanks
Old Feb 22, 2008 | 06:20 AM
jpetty's Avatar
jpetty
Great info Guys. The modules from Cyclegadgets is along the lines of what I want, but moving the aux jack inside the wing....killer.
Thanks.
Old Feb 22, 2008 | 07:08 AM
Araba Shriner's Avatar
Araba Shriner
My thinking on it is you could use a headphone "Y" adaptor and plug more than ono device into it. The adaptor creates a path into the sound system. Each device normally has an audio output volume control, so you should be able to balance each device. I see no reason why this shouldn't work.
Old Feb 22, 2008 | 07:23 AM
Copper Hog's Avatar
Copper Hog
I have the Kennedy system in my garage begging to be installed. I bought the switcher and the OEM cables that plug directly into my streetpilot and IPOD. These not only provide power out, but audio in. Still has to plug into the AUX jack in the front of the radio though. I would love to find a way to get get the AUX in to plug in inside the bat wing.
Old Feb 22, 2008 | 08:01 AM
NoKenDo's Avatar
NoKenDo
ORIGINAL: Copper Hog
Copper Hog,
Check this out. pirateeye sent me the link
http://www.cvoharley.com/smf/index.p...44.0;topicseen
