biggest rear tire
Old Feb 22, 2008 | 10:03 AM
lkr0's Avatar
lkr0
Default RE: biggest rear tire
me too; had to take the belt guard off it was rubbing
ORIGINAL: chappy_2336
Ive got a metzeler 160 60 18, Yeah it could be + or- a few mm depending on your manufacturer and actual wheel width etc.
Old Feb 22, 2008 | 10:06 AM
etrader's Avatar
etrader
Hogpro actually advises a Metzeler 150 (18"). The 160 is radial construction...clearance & handling issues are possible.
Old Feb 22, 2008 | 10:35 AM
Bobzilla's Avatar
Bobzilla
I am running a 4 1/4 rim not rubbing on belt guard or any thing else only had one ride on it since going to the 18"&21" rims but it felt great so far thought it handeled a little better will be lowering front as soon as parts get in it has for sure raised the bike up a bit not sure if I want to go just 1" or maybe more any help on that ?
Old Feb 22, 2008 | 10:39 AM
etrader's Avatar
etrader
Biggest (diameter) front tire...23" Avon COBRA
Old Feb 22, 2008 | 03:19 PM
speedglide's Avatar
speedglide
Thanks for the response Bobzilla!!! I took a bit of a gamble from reading some responses here and ordered a 21x3.25 front and 18x4.25 rear with a 160mm. I wanted the 160 for the higher load capacity and smoother ride inherent with a radial to counter a bit of a harsher ride associated with a lower profile tire. I didn't see the possible contact areas as a big concern, the belt guard can be trimmed, the inner fender lips can be pinched in, and worst case, I can shim the final drive pulley out an 8th or so with shims available all over the net if the tire may happen to be too close for comfort to the belt.
As far as lowering goes, you would have to lower it 1" to counter the increase in dia of the 21", but more is up to you. I"m lowering the rear an inch, so I'll be lowering the front 2" overall...
Old Feb 22, 2008 | 04:17 PM
gunnert's Avatar
gunnert
I mounted a 160mm on a stock FLHXI with no clearance problems.
Old Feb 22, 2008 | 04:27 PM
speedglide's Avatar
speedglide
ORIGINAL: gunnert
What year? What width wheel?
Jason
Old Feb 22, 2008 | 05:44 PM
Tinkermc's Avatar
Tinkermc
stock rim
Old Feb 22, 2008 | 06:05 PM
prc1333's Avatar
prc1333
Etrader, that is a beautiful bike.
Old Feb 22, 2008 | 07:16 PM
MustBBrent's Avatar
MustBBrent
ORIGINAL: prc1333
Forget the bike... that is an awesome avatar/g-friend. That top is kickin'
