I have been reading past threads about tires since I will need a new one come this summer. I would like to change it before I even start riding this spring. Between the Metz 880, the D402's, and the D E3's I beleive the E3 sounds like the best choice for mileage. Do they make this tire for my stock rim on the back and if so what size would that be? Also, can I run it with the stocker on the front? Thanks for any ideas!
You can see the diff in tread depth and load rating. Width is a touch lighter and will need attention when installing. Only comes in Blackwall and is Radial Biased ply construction.
