5th Gear Whine/Clatter
Old Feb 27, 2008 | 04:23 PM
  #41
albertasaurus's Avatar
albertasaurus
Default RE: 5th Gear Whine/Clatter
pittguy... may I ask what you ended up paying to have the IDS installed, and how long it took?
Thanks
Old Feb 27, 2008 | 10:32 PM
  #42
DrBob81's Avatar
DrBob81
Isolated Drive System part #40287-07 $305 plus about 2 hours labor
HD catalog page #461
Before IDS 5th gear sounded like a can with rocks in it and 6th made a loud metalic clacking below @80 mph
After IDS 5th gear just a whine and 6th no noise at all
This was on 07 FLHTCU
Old Feb 28, 2008 | 09:09 AM
  #43
albertasaurus
ORIGINAL: DrBob81
DrBob81,
Thank you for the information. This is the way I'm going to go, along with 75W90 synthetic tranny lube.
Cheers!
Old Feb 28, 2008 | 03:08 PM
  #44
pittguy's Avatar
pittguy
Al PM sent
Old Feb 28, 2008 | 03:39 PM
  #45
UltraKla$$ic's Avatar
UltraKla$$ic
ORIGINAL: hogdoc
Sorry choochoo there was no mid year change to "fix"a problem that doesnt exist. The '07 trans is the same all year. A bit of gear noise is not a problem, this has been beat to death and not 1 trans has blown up due to 5th gear. 5 speed bikes made theSAMEF"N NOISEin 4th gear. The problem comes from using to light of an oil in a gear box. USE GEAR OIL IN A GEAR BOX! I guess you never drove a Chevy with a Muncie trans, talk about gear noise. The IDS is for import riders converting to HD.
Baker is a smart man and found a great way to get $700.00 out of all these new riders by fixing a "PROBLEM" that doesnt exist. My hat's off to him for being a great entrepenuer!
You seem to be bitter and a little sue happy!
Absolutely agree 100% with this whole reply.
Old Feb 28, 2008 | 05:58 PM
  #46
Faulkner's Avatar
Faulkner
IDS is the best mod I've done to my 07 Ultra. Absolutely runs smoother and quiter than before.
Old Feb 28, 2008 | 06:24 PM
  #47
DrBob81's Avatar
DrBob81
Once you put the IDS on, you can run any lube you want.
Without ever riding the bike, these guys will tell you what's wrong with it. Gimme a break. That's the same crap I got from the dealer.
Old Feb 29, 2008 | 05:00 PM
  #48
BM83's Avatar
BM83
My guess would be that the reason there is not a lot of talk about noise in the dynas and soft tails is because they do not have fairings and/or fairing lowers to "reflect" the noise back to the rider, and those bikes are significantly lighter than a bagger so not as likely to lug it in a higher gear. I personally ride at or above 2000 rpm so as not to lug the bike. I have not noticed any clatter but gear whine is going to be there by design.
Old Feb 29, 2008 | 05:26 PM
  #49
Dsanchez's Avatar
Dsanchez
ORIGINAL: albertasaurus
Thanks
You can get it for 198.00 from Zanotti HD in Pittsburg or try talkin your dealer into matching their deal like I did. Save even more by putting in on yourself...if you have a lift or can borrow one its pretty easy stuff.
Old Feb 29, 2008 | 07:33 PM
  #50
DrBob81's Avatar
DrBob81
Keep guessing. Dyna and softail have a different length primary.
The 5th gear noise can be affected by diff tranny lube.
The 6th gear noise can be affected by diff primary lube.
HD Syn 3 10% improvement.
Redline 60% improvement.
Harley fixed it by changing the rear pulley.
That makes it some kind of resonance thing.
Harley won't cover it under warranty because it's a noise not a mechanical failure.
Oh, and it's also temperature dependent. No noise below @65 deg.
Requires a special HD tool to press in the bearing. Not a DIY.
Why are some bikes horrible and some not affected?
I have no idea. Or maybe it was all in my mind.
