Cylinder Temp Variance
Old Feb 27, 2008 | 10:27 PM
40 Knuck's Avatar
40 Knuck
Default Cylinder Temp Variance
Curious if anyone knows the normal cylinder temp variance between front and rear cylinders on the touring models.
Old Feb 28, 2008 | 09:24 AM
rbabos's Avatar
rbabos
Default RE: Cylinder Temp Variance
I think that 20-50 degrees would not be unusual, unless the mixture and timing is changed for the rear cylinder to bring them closer together.
Ron
Old Feb 28, 2008 | 11:17 AM
boiserider's Avatar
boiserider
Just checked mine yesterday. Air temp was 53deg. and front cyl. was 275 and rear was 320.
I was checking at the spark plug area. Also checked exhaust outlet area and the spread was the same.
This was within 2-3 min. of shut down after 30min ride.
I have 08 RG with Fuelmoto/Rush slipons PC111 and Fuelmoto map.
Old Feb 28, 2008 | 11:34 AM
cruiser85257's Avatar
cruiser85257
Boiserider:
That's running Hot. On a 53 degree day with a fuel mngt unit you should be running down in the 200's. I would talk to Jamie about that.
Old Feb 28, 2008 | 11:46 AM
DeJavu's Avatar
DeJavu
Don't know if it applies to newer models, but I had a temp guage on the rear cyl of my '80 FLT. With head or tail wind the rear was hotter, if a side wind the ran pretty close, if I kept feet on the floorboards it was hotter, highway pegs cooler. Air flow made a big difference (295*-260*). Air temp made little difference.
Old Feb 28, 2008 | 11:53 AM
captsam54's Avatar
captsam54
ORIGINAL: boiserider
Sounds like you need a better map..!!
RickJames Bish
Jul 30, 2014 11:04 AM
drspencer
Jun 1, 2011 07:27 PM
Bedore
Sep 21, 2010 11:35 PM
Beaver 550
Shovelhead
Oct 21, 2009 08:09 AM
t150vej
EVO
Jul 31, 2008 09:14 AM
