Going with 18's
Old Feb 28, 2008 | 10:42 PM
Street Glider's Avatar
Street Glider
Default RE: Going with 18's
Here's a picture of the wheels:
They are manufactured by MC Motorsports:
http://www.mcmotorsports.com/
And are available though them directly and on eBay, which is were I found them and the only place I've ever seen them.
The only reason I can give you to move up to 18" is to show a little more wheel, which gives a much nicer look.
Old Feb 29, 2008 | 09:32 AM
Street Glider
Anyone else running these wheels?
Old Feb 29, 2008 | 09:39 AM
steveh326's Avatar
steveh326
I'm thinking I am just gonna remove my belt guard totally and run a 160. I been running my belt drive yamaha without one for 75k miles no issues. The biggest exposure I ever heard was maybe picking up a rock and having it poke a hole in the belt, but its never happened to me in that many miles so I think the risk is low.
Old Feb 29, 2008 | 11:07 AM
Street Glider
ORIGINAL: steveh326
That's an interesting thought. I wonder what real problems there could be with running w/o one?
Old Feb 29, 2008 | 11:09 AM
THNDR's Avatar
THNDR
Those are hot! I'm curious on price and if anyone else has them already - how's fit & finish quality?
Old Feb 29, 2008 | 12:33 PM
onedae's Avatar
onedae
I've got 18's front and rear and run the Metzeler 880's - 140/70 in the front and 150/70 in the rear. No problems although it is a close fit. I know 2 guys thattried 160's in the rear and had to remove the belt guard and even then they had a bit of rubbing. As to the load rating, the Metzeler 150's are fine - never had any problem with 2 up and a load. Save yourself the headaches and go with the 150 on the back.
Old Feb 29, 2008 | 10:56 PM
Street Glider
ORIGINAL: onedae
I've got 18's front and rear and run the Metzeler 880's - 140/70 in the front and 150/70 in the rear. No problems although it is a close fit. I know 2 guys that tried 160's in the rear and had to remove the belt guard and even then they had a bit of rubbing. As to the load rating, the Metzeler 150's are fine - never had any problem with 2 up and a load. Save yourself the headaches and go with the 150 on the back.
Are you happy with the ride after going to 18"? I'm thinking 150 is the way to go. I think if I put the 160 on, it would always be in the back of my head that the tire was rubbing, or going to rub and eventually give me a bad day.
Old Mar 1, 2008 | 01:20 AM
hogdoc's Avatar
hogdoc
Loose the belt gaurd, run the 160
Old Mar 1, 2008 | 02:21 AM
VARDR's Avatar
VARDR
I am thinking about doing something similar. Would there be any issues with running a 16150/70 on the rear and 18 140/70 on the front? I have seen some scoots with this set up and really looks good. Does anyone have this setup and is there any issues with handling?
thanks
SG '08
Vivid Black
Old Mar 1, 2008 | 10:31 AM
mrbriang's Avatar
mrbriang
the 160 fits great with just a little lower guard trim...or removal. i had an minor and looks great. 18's on the SG would look sweeeeet!! please post a pic of those mc wheels when mounted.
