Clutch Adjustment
Old Mar 8, 2008 | 08:28 PM
OnTheFence's Avatar
OnTheFence
Default Clutch Adjustment
Did my 5k today. That jamb nut on the clutch took much more effort to pop loose than it did to reach 10ft pounds tourqing it back down. Is that common?
I am just worried that it isn't tight enough and I'll end up with a big mess on my hands.
Old Mar 8, 2008 | 08:44 PM
Ram's Avatar
Ram
Default RE: Clutch Adjustment
http://www.expertvillage.com/video-s...aintenance.htm
check out the sections on clutch adjustment. it was posted by a member a few days ago or so.
pretty good site, lots of info. it should answer all your questions.
Old Mar 8, 2008 | 08:58 PM
rjmac53's Avatar
rjmac53
Good link.
Old Mar 8, 2008 | 09:25 PM
ratcat's Avatar
ratcat
I help several folks ajust there clutch, and what you say IS common. Get your self a Craftman off set 11/16 wrench from Sears and thing will go a lot smoother. That Darn nut does't really do anything but act as a jam nut, to lock the through out bearing push rod in place. Good luck, a clutch ajustment is a little trick at first.
Rusty Axle
Shovelhead
17
Jul 7, 2021 05:20 PM
ElectraJim
Nov 24, 2016 09:45 AM
Sand850
General Topics/Tech Tips
Nov 3, 2016 07:27 AM
blueridge
May 4, 2014 01:43 PM
DAWG_6
Mar 5, 2012 07:58 AM
