Is this a problem, or a side effect?
Old Mar 12, 2008 | 10:49 AM
Mako Shark's Avatar
Mako Shark
Default Is this a problem, or a side effect?
Just put a set of Rush 2.5 slip ons on my 04 roak king carb model.
It pops everytime I let off of the throttle. Very annoying. Should I go to a smaller baffel, or live with it? I like noise, but not this stuff.
Old Mar 12, 2008 | 10:51 AM
eglidetrike1's Avatar
eglidetrike1
Default RE: Is this a problem, or a side effect?
Your gonna have to adjust the fuel mixture.
Old Mar 12, 2008 | 11:04 AM
lkr0's Avatar
lkr0
correct -- do you havea carb or FI--also have you done any other mods?
ORIGINAL: eglidetrike1
Old Mar 12, 2008 | 11:13 AM
Tinkermc's Avatar
Tinkermc
some adjustment may be necessary
Old Mar 12, 2008 | 01:03 PM
SPARKY01's Avatar
SPARKY01
SAME THING ON MY 08. WENT WITH 1.75'S AND IT STOPPED...
Old Mar 12, 2008 | 01:39 PM
Mako Shark's Avatar
Mako Shark
Like I said in the opening, it is a carb.
I was running screamin eagle slip ons, with no problem,
Basically stock, but I have had the air cleaner upgrade, dynojet kit and dyno tuned with the other pipes.
I just hate to make too quiet, I guess a matter of preference.
Thanks for the info!
Old Mar 12, 2008 | 02:51 PM
FastHoss's Avatar
FastHoss
All motors pop under decel,just depends on muffler or lack of,try not shutting off throttle all the way when shifting,always keep a little on,your pop will go away.
Old Mar 12, 2008 | 03:02 PM
CREEPSHOW's Avatar
CREEPSHOW
I needs retuned for that baffle!
Old Mar 12, 2008 | 05:57 PM
lecomte38's Avatar
lecomte38
Pops or blubbles on deceleration? It sounds like your main jet is too big; go back to 45/190 and try it. play with you needle height.
Don't need no stinkin dyno for a carb.
Old Mar 12, 2008 | 06:03 PM
nujohn's Avatar
nujohn
Maybe leaking airTry re-tighting your muffler Good luck
