Is this a problem, or a side effect?
Old Mar 12, 2008 | 06:04 PM
SG 1's Avatar
SG 1
Default RE: Is this a problem, or a side effect?
Mine poped when I installed the Rush 225's. Not enough ajustment on my DFO to stop it.Installed the fulsac tru dual conversion and no more decel pop.
Old Mar 12, 2008 | 06:16 PM
izzy's Avatar
izzy
I'm with nujohn. Retighten your slipons and use harley clamps if you have 'em.
Old Mar 12, 2008 | 06:21 PM
PhoenixClassic's Avatar
PhoenixClassic
I had 2.25's and it popped like crazy. Went to 1.75's and it was alot better. My bike's an EFI, though. You're in a better position (read cheaper fix) with a carb.
Old Mar 12, 2008 | 06:23 PM
iclick's Avatar
iclick
Try screwing out the idle mixture screw 1/2-turn at a time. If it has never been adjusted it may have a plug on it that must be removed first.
Old Mar 12, 2008 | 06:26 PM
iclick's Avatar
iclick
ORIGINAL: lecomte38
Pops or blubbles on deceleration? It sounds like your main jet is too big; go back to 45/190 and try it. play with you needle height.
Don't need no stinkin dyno for a carb.
The main jet has nothing to do with the mixture at 0% throttle on the CV carb, which is what he is describing. If the idle-mixture is too lean it can cause popping on decel. I suggested he screw the idle-mixture screw out a bit at a time, trying it at each setting until it stops. Another suggestion to seal-up the muffler may also help.
Robtarra39
Aug 18, 2013 07:54 PM
roundy
Mar 29, 2012 10:21 AM
rounder
Exhaust System Topics
Feb 3, 2008 01:35 AM
Hurricane
Aug 25, 2007 09:01 PM
anubisss
Jun 3, 2007 07:28 AM
