Battery Bolts coming loose
Old Mar 12, 2008 | 09:52 PM
Retired_Ted's Avatar
Retired_Ted
Default RE: Battery Bolts coming loose
I wouldn't recommend using loctite on the battery. I'll research your problem and try to get back.
Old Mar 13, 2008 | 03:35 AM
BirchwhiteHD's Avatar
BirchwhiteHD
Steve,
Thanks for posting this question,I have the same problem with the neg side of the battery coming loose all the time,thought i was having a battery problem because it didnt seem to have the zip while cranking over hot,i ended up replacing the battery because it was 4 years old and figured it was due,something i keep my eye on now and check it once in awhile just to see if it has come loose,no problem since replacing the battery,so maybe it does have something to do with the threads on the terminal
Old Mar 13, 2008 | 05:32 AM
maineultraclassic's Avatar
maineultraclassic
Yes, I know my negative terminal threads are going to crap...............this last time I tightened it up I could feel it "stripping".
Battery is 3-4 years old.......but is still in great condition............I hate to replace it right now just for new threads.
Steve
Old Mar 13, 2008 | 06:04 AM
kyote's Avatar
kyote
You may wanna try getting those nuts with the Nylon inserts. They may cure the problem...
Old Mar 13, 2008 | 09:07 AM
hogdoc's Avatar
hogdoc
ORIGINAL: maineultraclassic
Steve
No matter how GOOD the battery is, if there are no threads left the battery is done.
Loctite IS NOT CONDUCTIVE and even blue could be harder than the lead and pull the threads, or what will actually happen is deform the threads when the bolt is removed.
A 3-4 year old battery is 3-4 times the useful life in a Softail so we are way ahead of those riders!
Old Mar 13, 2008 | 09:22 AM
scootertramp's Avatar
scootertramp
Really? Useful life? Cause I've only had 3 batteries in my 93 softail since january 1993! And one I just changed for ***** & giggles! If you ride and maintain em, they'll last a long time! Unfortunately, regularly puttin a 10mm to it is part of maintaining it.
I do find the bolts loose on my Glide real regularly. I blame the tender connection for that.
Old Mar 13, 2008 | 09:31 AM
jsimo7's Avatar
jsimo7
Bad threads = bad battery 4yrs of service is good
Old Mar 13, 2008 | 09:35 AM
lecomte38's Avatar
lecomte38
Blueballs suggested : JB Weld
Old Mar 13, 2008 | 10:04 AM
nmfxstc's Avatar
nmfxstc
Try wrapping the bolt threads with somke steel wool...almost as good as a heli-coil job!
Old Mar 13, 2008 | 03:56 PM
Retired_Ted
The mechanic I spoke with said that most of the time, loose battery connections are caused by either the battery moveing and not tightened down properly or the cables being allowed to move or vibrate and not being secured properly.
