Leaking brake fluid
Old Mar 14, 2008 | 07:39 PM
wideopen1967's Avatar
wideopen1967
Default RE: Leaking brake fluid
Happened on my 07 RKC. Got to looking and realized the moco had installed the cap backwards.....
Old Mar 14, 2008 | 08:24 PM
Comfortably Numb's Avatar
Comfortably Numb
Flip the lid around. There is a front and a back to them......and if you want a chrome lid, don't buy one. I have one NEVER OPENED that I will GIVE you. Just give me your address. I'll send it to ya.
I bought one and then discovered that one came with the chrome master cylinder kit I bought.
CN
Old Mar 15, 2008 | 06:34 AM
Uncle Scrooge's Avatar
Uncle Scrooge
Check the simplest things first. Leak on my 06 EG disappeared when I drew the fluid down a tad.
Old Mar 15, 2008 | 06:41 AM
captjon37's Avatar
captjon37
Mine started to leak a little after i did the chrome switches. I think it had something to do with the master cylinder laying on its side while i changed the switches. live and learn i guess.
Old Mar 15, 2008 | 12:21 PM
Big Peter's Avatar
Big Peter
ORIGINAL: roxnatwist
Mine leaked on my 07 RKC. I was more concerned with the brake fluid getting blown onto my tank and screwing up the paint. I immediately replaced the stock cover with a chrome one and new gasket; I haven't had any leakage since. I think it's a common problem but you'll never get the MoCo to own up to it.
DOT 5 brake fluid will not screw up the paint.
Peter
Old Mar 15, 2008 | 01:40 PM
Drifting Texas's Avatar
Drifting Texas
I didn't realize mine was leaking until I noticed the paint bubbling up on the lid. I checked the screws and thightened them. I ended up taking the lid off and stripping the paint and repainting it. Seems to be fine now. Brake fluid is the best paint stripped in the world so be careful. Check those screws regular.
Old Jan 3, 2010 | 03:00 PM
Molzy's Avatar
Molzy
Default 08 flhtcu
Just noticed mine seeping out the front resevoir today from around the seal. Been sitting in my garage for 6 weeks with only idling as I trouble shoot a power commander matter.
Old Jan 3, 2010 | 03:04 PM
davescreation's Avatar
davescreation
mine leaked on my bob, moco replaced it 3 days later the leak was worse got fluid on my tank and front fender. Moco replaced the whole master cylnder and sprayed my tins
Old Jan 3, 2010 | 03:53 PM
strtarrow's Avatar
strtarrow
I have the chrome front master on my 01 RK. Hell, not much that isn't chrome. Anyway the only time mine leaked was when I had an Indy install chrome calipers and polished rotors. Most every connection was loose so I filled it with fluid, tightened everything and have not had a problem since. Needless to say that was the last time I used that guy. I don't care if somebody smokes pot but don't do it when you are working a my bike....
Old Mar 18, 2010 | 06:48 PM
bjones's Avatar
bjones
My 09 sg front master cylinder was leaking around cap took to dealer they replaced cap. 2 days later the sob is leaking again. Taking it back tomorrow and they are replacing cap this time.
