Need zumo help please....
Old Mar 14, 2008 | 09:57 AM
leeinmemphis's Avatar
leeinmemphis
Default Need zumo help please....
Hey everyone,
I have a zumo 550 that I am trying to upload some routes to and everything appears to be uploading fine but when I turn the unit on to make sure they are on there, the unit says there isn't anything there. Am I missing a step? Please help if you can I have a group ride tomorrow and really need this route because I'm likely to be leading part of it. Thanks.
Old Mar 14, 2008 | 10:15 AM
RoadKing52's Avatar
RoadKing52
Default RE: Need zumo help please....
After you downloaded the route did the Zumo tell you new data found? Or would you like to import new data?
Old Mar 14, 2008 | 10:21 AM
leeinmemphis
no it didn't ask that.
Old Mar 14, 2008 | 10:23 AM
texan321's Avatar
texan321
Then you aren't uploading the information properly. Are you sure you are pointing it to the correct file?
Old Mar 14, 2008 | 10:32 AM
jackja25's Avatar
jackja25
You have to use map source to upload a route either to the SD card or directly to the unit. Best place to go to get your answers is zumoforums.com . An excellent resource for the Zumo owners. You can also get the HD POI files here.
Old Mar 14, 2008 | 01:58 PM
leeinmemphis
yeah it is saying that the info is loading up successful but when I turn the unit on to import it doesn't look like it is there. I've tried different sd cards so that isn't the problem. I sure need to get this to work. I'll try to call garmin in a minute.
Old Mar 14, 2008 | 02:31 PM
chappy's Avatar
chappy
Hi,
If you have loaded your route properly,
andyou have
selected "Where to?"
and that didn't work
try
select "Where to?"
then select "Recently found"
some times a route will end up there.
if these don't help,
I agree with eariler post about www.zumoforums.com a great site
or, another good place to check is;
https://my.garmin.com/mygarmin/custo...rminHome.faces
good luck
chappy
Old Mar 14, 2008 | 04:04 PM
leeinmemphis
well I was able to get it fixed. I called garmin and apparently for some reason the computer had conflicts with the drive letter it was assigned. Garmin told me to re-assign the letter and it worked fine. I have spent most of the day trying to get it to work. I restored the windows to back to last week, did master re-sets on the zumo, reloaded software etc. Sure am glad they could help me. Thanks again fellas. I appreciate the help! I was worried to death about taking all those people tomorrow on a ride and having to fight with a map while riding.
-lee-
Old Mar 14, 2008 | 04:14 PM
XTrooper3936's Avatar
XTrooper3936
Glad you got it squared away.
Old Mar 14, 2008 | 04:41 PM
chappy's Avatar
chappy
Glad it worked out for!
I know first hand how frustrating it can it!!
But, like you said in so many words, It beats fighting with a map!!
When it's working right!
chappy
jasnusc
2014-2024 Touring Models
96
Jan 23, 2015 07:20 PM
TakeNoCrap
Apr 21, 2008 04:24 AM
brainfrz
Mar 3, 2008 09:39 AM
mja51
General Topics/Tech Tips
Sep 13, 2007 09:43 AM
Lee n Tj
Jul 23, 2007 08:42 PM
