My brake light stopped working for some reason. I checked the bulb both filaments look connected, although the filament that is not curled has a slight bend on one side. I also checked the the little fuse block on the left side. The brake relay is there and all 9, 15amp fuses are good plus the 1, 10amp fuse. Any input will be great.
Does it come on with just the front brake applied?Might be that brake pressure switch off the rear brake down below the frame.I think it cost about 15 bucs.
I haven't checked that yet. Im headed to a dealership this morning to view the traveling museum
that harley touring around and im going to get them to check it out. its still under warranty. Ill let them worry about it ! Thanks For everything
Have you tried both hand and foot? The foot switch on mine quit at 1 1/2 years and almost got me killed. I had been checking the brake light with the hand lever and had no clue the foot switch was out.
