Steering head bearing adjustment
Old Mar 16, 2008 | 01:07 AM
hogdoc's Avatar
hogdoc
Default RE: steering head bearings
ORIGINAL: hogbag07
Thanks hogdoc
Mine swings 2 1/2 times but feels lose and I can feel a slight clunk when dabbing the brakes.Thanks for your info it made more sense to me than the service manual did. I will check the stem nuts tourqe and try that first
Check the caliper bolts, more likely check your front motor mount. If its shot it could feel like the front end is loose.
Old Mar 17, 2008 | 04:18 AM
hogbag07's Avatar
hogbag07
Thanks Hogdoc
Old Mar 21, 2008 | 01:10 AM
hogbag07's Avatar
hogbag07
The 1 1/2 inch nut on top was lose.I tightend it up to 60 to 80 ft lbs. I checked the swing theres 2 1/4 swings theres no movement now Thanks hogdoc
Old Mar 21, 2008 | 01:17 AM
hogdoc's Avatar
hogdoc
Anytime!
Old Mar 21, 2008 | 01:36 AM
sumdumtech's Avatar
sumdumtech
if that 1 1/2 nut was loose thats where your noise was comming from. your dealer should have been checking that!
[IMG]local://upfiles/55106/1495256F90CA43339F42D75897B7B91B.jpg[/IMG]
Old Sep 21, 2010 | 12:01 PM
miken488's Avatar
miken488
Default Clutch Cable
Do you need to remove the clutch cable to check the swing? It seems as if this pulls or restrains the bars from swinging freely.
Old Sep 21, 2010 | 03:17 PM
jasnusc's Avatar
jasnusc
Yes. You should remove clutch cable and throttle cable if you have one.
Old Oct 2, 2010 | 12:31 PM
BuckeyeRider's Avatar
BuckeyeRider
My front end seems loose. I can feel a clunk when I hit a small bump or hole. Also have trouble with low speed wobble. (keeping it in line at 5 mph or less)
I can it the bike up level. I have a 08 but theres a cross member under the bike and either the front or rear tire is higher so with the swing test I only get a turn and a half.
I got it broke down and was able to get the the star nut but not sure if I got it turned any.
Old Mar 19, 2011 | 08:52 AM
wtkpga's Avatar
wtkpga
Thanks Hogdoc. Adding to the list of thing to check.
Old Mar 19, 2011 | 12:05 PM
larsfum's Avatar
larsfum
Also remember to grease the neck fitting while you are in there. If it is dry that may cause a clunk when going over bumps.
