air in the shocks???
Old Mar 17, 2008 | 03:22 AM
2fas4u2's Avatar
2fas4u2
Default RE: air in the shocks???
what is the recommended range for stock shocks solo versus 2up...mine are at 10psi and i check every month
Old Mar 17, 2008 | 03:30 AM
biz44's Avatar
biz44
Both Progressive Suspension and Harley Davidson sell a "low pressure" air pump/gauge. Nothing for nothing, but I thought I would just add that you should NEVER use a unregulated air supply....or a higher pressure line to fill the shocks. If you do try to introduce air at a high pressure, chances are you will destroy the seals. So stick with a hand pump, and read your owners manual to get a ball park of what PSI they should be set at......and yes the lowered Street Glide rear suspension can take a bit more PSI than the full length units.
Old Mar 17, 2008 | 05:59 AM
Chuck1's Avatar
Chuck1
What Peekaboo said.
Old Mar 17, 2008 | 06:25 AM
rocknrod's Avatar
rocknrod
Like BIZ44 said, read your owners manual.
I put 10 PSI in mine with the HD hand pump.
Old Mar 17, 2008 | 07:10 AM
dog155's Avatar
dog155
Mother and I run 20 lbs same ride,Sweet!!
Old Mar 17, 2008 | 07:44 AM
reeac's Avatar
reeac
Mine came serviced to 18psi I keep it at 25.
Old Mar 17, 2008 | 08:02 AM
sumdumtech's Avatar
sumdumtech
Every setup I do I put at least 12lbs in. Is something my dealership does ...
[IMG]local://upfiles/55106/72E7D77B0EFA4BC88B6DE45FB7F4409C.jpg[/IMG]
Old Mar 17, 2008 | 08:25 AM
rodneyj123's Avatar
rodneyj123
With 0 psi in my SG I can get my feet flat on the ground but the bike bottoms out on large bumps and dips. With 15 psi it doesn't bottom out and rides very smooth but I can't put my feet flat on the ground at stops. I live with 15 psi for the smoother ride and just don't put my feet flat on the ground.
Old Mar 17, 2008 | 08:52 AM
Secretec's Avatar
Secretec
30 lbs
Old Mar 17, 2008 | 09:47 AM
IronLegend's Avatar
IronLegend
Doesn't hurt to check them on a regular basis Thunder and it only takes a minute.Any application which uses air canor will eventuallyleak for any number of reasons. Itmay be obvious or barely audible but chances areit will happen. I check mine weekly.
