passenger floor boards
Old Feb 2, 2006 | 06:16 PM
ric's Avatar
ric
5th Gear
Default passenger floor boards
I started to install chrome covers so when boards are up it looks better. They dont seem
to fit perfect there is a gap, the chrome cover dose not go all the way to the top of the board
its close but not all the way. Has any one replaced these themselves. I also took the floor board insert
out and one of the rubber nipple that secures the board down broke. I'm thinking of using silicone but would
make it tough to remove in the future.
Thanks in advance for anyones help...
Old Feb 2, 2006 | 07:50 PM
MACK's Avatar
MACK
Default RE: passenger floor boards
if you are not getting new custom inserts just ask your dealer for one that was a takle off. we use to throw thenm away.
Old Feb 2, 2006 | 08:21 PM
spartns's Avatar
spartns
First, welcome to the forum. You'll have a lot of fun here and learn a lot. The lower covers don't go all the way to the top of the floorboard. There is a little gap. As stated above, check with your dealer for take-offs. If they don't have any, get the new ones that will match what you're putting on the front (you're gonna do that). Be sure to lube them up well. Use soap or WD-40 you should be set.
Old Feb 3, 2006 | 07:44 AM
ric's Avatar
ric
5th Gear
Thanks for the feed back. My problem with the insert is that it is the skull theme one I installed last year.
Terrance Kellogg
May 21, 2018 09:30 AM
streetglide6
Mar 7, 2016 04:55 PM
sabre0909
Touring Parts
11
Jun 13, 2014 02:15 PM
knvduhon
Mar 14, 2011 10:02 PM
Avmech
May 4, 2007 02:38 PM
