Brake fluid
Old Mar 18, 2008 | 04:29 PM
bdeuce's Avatar
bdeuce
Default Brake fluid
Book calls for dot 4 brake fluid,but all I can find is dot 3 an 4 Valoline makes it.Is this ok to use or do I have make a trip to the stealer
Old Mar 18, 2008 | 05:44 PM
Yogibear's Avatar
Yogibear
Default RE: Brake fluid
There is a chemical difference between the two types. You could have some component seal failures (unlikley) if you use dot 3 in a dot 4 system. Also dot 4 has a higher heat rating then dot 3.
You should be able to find dot 4, I'd keep looking.
Old Mar 18, 2008 | 05:47 PM
o5ultra's Avatar
o5ultra
dot 4 try auto zone or an o'rieliys they should have it
Old Mar 18, 2008 | 05:50 PM
cwickgo9's Avatar
cwickgo9
You should be able to find DOT4 at any auto parts store
Old Mar 18, 2008 | 06:00 PM
eglidetrike1's Avatar
eglidetrike1
Absolutely do not use dot 3. you need dot 4.
Old Mar 18, 2008 | 07:22 PM
maineultraclassic's Avatar
maineultraclassic
Didn't they use DOT 5 for a couple of years?
I should really change out my brake fluid.........27000 miles on it so far, I'm sure it's pretty nasty.
What years used which fluid?
Steve
Old Mar 18, 2008 | 08:16 PM
Neil's Avatar
Neil
I think they changed from DOT 5 to DOT 4 in 2005.
Neil
Old Mar 19, 2008 | 04:03 AM
Big Peter's Avatar
Big Peter
ORIGINAL: bdeuce
I am still using DOT 5
Do not use DOT 3 ( seal failure )
Peter
Old Mar 19, 2008 | 04:37 AM
benman's Avatar
benman
My '04 Ultra uses dot 5 (silicone). Do not mix as others have said.
Old Mar 19, 2008 | 05:48 PM
bdeuce's Avatar
bdeuce
Vavloline an castrol make a brake fluid that says on the bottle for dot 3 an dot 4 or exceeds dot 3 an dot 4 , I hit 4 auto parts stores today an no dot 4 brake fluid. Is it just bad timing hitting the stores .
