Gear Drive Cams
Old Mar 18, 2008 | 11:59 PM
Timex's Avatar
Timex
Default Gear Drive Cams
I am sure this has been asked before ..... but here goes anyway.
I have an 06street glide with rineharts, SERTand a screaming eagle air cleaner. Stock motor.
What gear driven cams would provide me with the best all around performance without doing any top end work.
Looking for an added "bump" in performance without spending a fortune. Thanks in advance.
Old Mar 19, 2008 | 12:30 AM
PapaTravis's Avatar
PapaTravis
Default RE: Gear Drive Cams
I have asked this before, and I have been recommended to try the HQ 0034. It works with the 88", and if you bump it to 95", it works great with it, as well. As always, check out the search feature... in fact, I am looking cams up I write this...lol
Old Mar 19, 2008 | 03:55 AM
Big Peter's Avatar
Big Peter
ORIGINAL: Timex
I am very happy with this outfit
www.sscycle.com/modules/instruction/uploads/51-1047.pdf
Peter
'99 RKC
S&S .510G gear drive cams
AN big sucker aircleaner
PC111 USB powercommander
SE pro performance pipes
Old Mar 19, 2008 | 05:07 AM
dawg's Avatar
dawg
I used the Andrews 26g kit in my 04 and then put in a 95" and was happy. The 26g kit can be had by American Classic Motors on ebay as an entire kit for under $500
Old Mar 19, 2008 | 05:25 AM
maineultraclassic's Avatar
maineultraclassic
Woods TW-6, HeadQuarters HQ-0034, Andrews 21 or 26, S&S 510.........they are all good bolt-in cams for a stage 1 88" motor.
Steve
Old Mar 19, 2008 | 07:30 PM
LARRY E's Avatar
LARRY E
Stage IV
You can e-mail Andrews from their web site for a recommendation. I just installed their 37G cams, they work with stock heads and have good low end torque("02 Electra, already had 95" with 10.25 to 1 comp.). I bought the kit from American Classic on E-Bay and saved enough to buy the tools and did it myself. Be sure to check your crank run out before you buy the gear drive kit - it must be less than .003 and when researching this installation I heard that some newer bikes exceeded this. I was real pleased with the result - it has 5th gear accelleration like it did in 3rd before.
0ut1aw
Feb 16, 2009 02:56 PM
OldPhat
Mar 4, 2008 03:27 PM
TOMCENTRAL
Exhaust System Topics
15
Aug 23, 2007 12:59 AM
Islander
Jun 28, 2006 10:47 AM
usacando
Feb 27, 2006 12:26 PM
