harley heated seat
Old Mar 28, 2008 | 05:56 AM
troutbum1971's Avatar
troutbum1971
Default RE: harley heated seat
Did that too... Thanks I think my seat is bad, as mine was wired wrong too, so I switched it also..... Nothing, nada, zip, zero.... Went to the dealer here in Berlin... he did something I did not even think about.... he took the seat off and hooked it up to a batery, same result nothing... But he checked plugs got 12 volts, checked resistance on the seat, got resistance, it just never got hot, not even warm???? so they ordered me a new seat... I feel bad for them... the seat here is almost 1200 euro's, about 2K US dollars.. I know they get there money back but they had to front it and it takes a few months for them to get it back...
ORIGINAL: bookworm
Hey, troutbum I had the same problem. Didn't bother to take it back to dealer since I am a hopeless tinkerer and don't have a lot of patience with the dealer.The problem on mine was with the one-into-two wiring harness connectorthat was wired incorrectly. This is the harness that sends 12V to the two seat switches. It is a four pin connector on the single end of the harness, but they only use two pins. They had wired the hot and ground to the to unused pin locations.I took the connector apart and moved the pins to the right holes. The polarity doesn't seem to matter since they do not take eitherwire to the seat frame. It was good to go after and just in time for cold weather last fall. Plenty of nice heat. I only use it on low even below freezing, but the bride likesherson high. I leave all the funny comments about that to the comics in the crowd.I thought I might be the only one that had the problem, but maybe they had a bad batch of these harnesses. It is worth looking into since it really is a nice seat when the heat is working.
Old Mar 28, 2008 | 06:20 AM
alame's Avatar
alame
well the good thing trout, your dealer is looking after you, I have heated seats in the car and same for me, couldn't do without them now
Old Mar 28, 2008 | 08:00 AM
troutbum1971
ORIGINAL: alame
We added remote start to the cars so our butts are nice and warm before we even get in the car!!!
Old Mar 28, 2008 | 08:05 AM
electaRICK's Avatar
electaRICK
Meancity cycles ,who has redone alot of seats here,, has mine as I speak, can install heater, same one HD uses, for less than $100 I think,,,get the better padding while at it!
Old Mar 28, 2008 | 08:21 AM
troutbum1971
maybe I should have looked into that first..... *****
ORIGINAL: electaRICK
Old Mar 28, 2008 | 08:32 AM
HawgriderPa's Avatar
HawgriderPa
I got mine on ebay last year. Guy moved to Fl from Maine... figured he didn't need it anymore.. was already tested for me!
Old Mar 28, 2008 | 08:40 AM
electaRICK's Avatar
electaRICK
ORIGINAL: troutbum1971
Well... I'm the "Go to " guy!!!
why?.... cause I'm a cheap sob. lol
if there is a EZ, quick, and cheap way to go,,I'll know about it!
Old Mar 28, 2008 | 08:42 AM
troutbum1971
Now I know expect a butt ton of PM's now
Old Mar 28, 2008 | 07:40 PM
BM83's Avatar
BM83
I have the premium sunray heated seat and love it. I ride all year except when there is alot of snow and ice, and this seat helps keep the a$$ cheeks warm on those 10 degree mornings.
hbsoldier3
Touring Parts
Jun 10, 2015 03:28 PM
scottt
2014-2024 Touring Models
44
Apr 14, 2014 10:06 AM
bberck
Jan 4, 2010 11:14 AM
Wally
Jul 23, 2009 06:20 AM
Bryman30
Sep 21, 2008 12:03 PM
