tweeter question
Old Mar 28, 2008 | 11:45 PM
kart11's Avatar
kart11
Default tweeter question
I have read some threads here about adding tweeters and I dont quite understand calculating ohms so my question is I have a set of JL audio 8ohm tweeters with inline crossovers can I parallel them to my 5-1/4 fairing speakers on my 07 SG with damaging the radio ?
TIA
Old Mar 29, 2008 | 06:07 AM
TexasRedneck's Avatar
TexasRedneck
Default RE: tweeter question
No
Old Mar 29, 2008 | 06:28 AM
biz44's Avatar
biz44
I thought you would need to use a 2 ohm set up.....no?
Old Mar 29, 2008 | 06:37 AM
Araba Shriner's Avatar
Araba Shriner
Rule of thumb... If you paralell a pair of speakers, add the total ohms for the pair being paralelled, divide by 2 to get the final load to the amp. If you use different ohm speakers when paralelling, the higher ohm speakers will work way too hard trying to keep up and probably not last. Not a good idea to mix like that.
Old Mar 29, 2008 | 08:49 AM
texas steve's Avatar
texas steve
ORIGINAL: kart11
TIA
I went through this in great detail with PEZ (Hogtunes I think) and it wont hurt anyting. Yes, it will drive it to two ohms, but ONLY at varing frequences (the Polks have a frequency circut board that comes with them), so the time your amp is pushing 2 ohms is not all the time just occasionally. No problem! And the sound difference is excellent! You can see one of the tweeters in the picture below on the top left. they fit perfectly there.
Old Mar 29, 2008 | 08:59 AM
kart11's Avatar
kart11
ORIGINAL: texas steve
ORIGINAL: kart11
TIA
Are the Polks 8 ohm also ?
Old Mar 29, 2008 | 09:41 AM
texas steve
The polks are 4 ohm as are the standard Harley speakers.
Old Mar 29, 2008 | 09:51 AM
PEZ's Avatar
PEZ
Hi there
If you go to the tech zone on our site www.hogtunes.com --there is a page I wrote on this topic--explains what and whyit will work and give fancy graphs too
Even though I suggest a 4 ohm will work--your 8 ohm will work just fine
JL Makes some real nice sounding stuff. In order to make the BEST SOUND, they would probably use a fabric dome on the tweet. This sounds the best but is like a sponge--remember--were not in a car here--and excessive moisture will kill thos tweets
For MC application always suggest a hard dome tweeter--will be metal, or plastic
Here to help if you have any questions!--PEZ
Old Mar 29, 2008 | 09:55 AM
kart11's Avatar
kart11
ORIGINAL: PEZ
Hi there
Thanks Pez, I do believe they are a textile dome tweeter. Cant wait to give them a try.
Old Mar 29, 2008 | 10:03 AM
kart11's Avatar
kart11
ORIGINAL: kart11
TIA
btw Texas Steve where did you get the gage trim ?
